1996 ES300 Cabin air filter
Old 12-09-12, 12:20 PM
mitmaks
mitmaks's Avatar
Default 1996 ES300 Cabin air filter
Is 96 equipped with cabin air cleaner?
Old 12-09-12, 12:36 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
It's a Lexus, it does.
Old 12-10-12, 01:33 PM
davensd
davensd's Avatar
Sadly that's not the case.
As most people with a '97 to 2001 found out the compartment exists but it's empty for a lot of people. Check your user manual for the location.
Dave
Old 12-10-12, 06:19 PM
morphh
morphh's Avatar
Does 94 es300 have cabin filter i checked but there is no filter should there be one there its right by the gas pedal.
Old 12-10-12, 06:37 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Like davensd said before, sometimes there are compartments for the cabin air filter but no air filter.
Old 12-10-12, 08:04 PM
ASG14
ASG14's Avatar
Even if it didn;t come with the filter, you can add it. I did on my '96 Camry.
Old 12-11-12, 08:09 PM
morphh
morphh's Avatar
what do u look up 94 es or 96 camry ?
Old 02-09-13, 12:43 PM
Grady78ss
Grady78ss's Avatar
My 92 es300 had no filter installed. I purchased a set, cleaned out the cavity ( lots of debris) and installed the new ones. Not so easy without instructions. the thin one goes in first , gets slid up and the large one goes under it. close the cover and your done.
Old 02-09-13, 02:29 PM
morphh
morphh's Avatar
ASG14 can i ask u some questions
Old 09-18-15, 09:31 AM
vbhalla24
vbhalla24's Avatar
Default 97 Lexus ES300 Gen1 cabin air filter replacement
Recently I changed cabin air filter on my 97 Lexus ES300 (Generation 1). I believe this model is closer to 96/95 lexus es300 as far as cabin air filter goes.
I left a youtube video too and put it in my comments on how i achieved it.
If anyone has questions do ask, I will be able to answer it since I got success at last.
Old 10-18-15, 02:10 PM
mitmaks
mitmaks's Avatar
Took out glove box lining on our 96ES300 and it does not have air filter or even a compartment for cabin air filter.
Old 10-18-15, 05:42 PM
JetsonES
JetsonES's Avatar
Sometimes it can be covered by a cloth material making it hard to spot.
Old 10-19-15, 05:03 AM
vbhalla24
vbhalla24's Avatar
Default es300 cabin air filter
Check my video posted on this thread regarding where I found the cabin air filter on 97 lexus ES300. It is visible and accessible after removing carpet under steering column. May be it is same for 96 model too (not sure) but you can check.
Old 01-14-19, 06:58 PM
MNJack
MNJack's Avatar
Forgive me for reviving this old thread, but there is some good info here. I have a 97 es300 (original owner), and I thought I should change the cabin air filter. I found a Youtube video which was a 98, and it showed me where to find it and how to change it. (The video posted above is unfortunately unavailable. I guess it got old). One of the comments on the video was from a 1997 owner who said there was a problem with his 97 that made it harder than the video. It really is a pain just to get to the thing. You have to pull the stiff carpet past the gas pedal, and there on the 97 is a cable that is zip-tied to hold it blocking the cover for the cabin air filter, which is pretty far up under the dash anyway. I may go back and snip the ziptie to get to the compartment, but it will be a major PIA. Very interesting to read that many have found empty compartments. Did these cars come from the factory without a cabin air filter installed?
I can't believe how difficult it is to access and change. I have a 2009 Honda CR-V. You just squeeze the glove compartment and it drops out of the way revealing a drawer you pull out with the cabin air filter. No tools required. If I tried hard I could change it in 10 seconds flat.
Old 01-14-19, 08:10 PM
Richardsr
Richardsr's Avatar
That’s what 10 years of engineering gets you. My ‘05 ES is the same. Easy peasy. Made me wonder why it was so choked full in spite of it being perpetually Lexus shop maintained.
MNJack (01-15-19)
Quick Reply: 1996 ES300 Cabin air filter
