changing low beam bulbs 04 es
Old 12-05-12, 02:44 PM
Timothyj
Timothyj's Avatar
Default changing low beam bulbs 04 es
Has anyone know a easy way to change the low beam bulbs on a 04 es? Drivers side is the worst. Trying to get the bulb lined up, and get that stupid spring to hold the bulb in. Dumb. Or is this just a way to take it to a dealer and get ripped off to get it replaced.
Old 12-05-12, 03:34 PM
speedkar9
speedkar9's Avatar
Taking out the battery will give your hands enough room to maneuver the bulb behind the headlight.
Old 12-05-12, 03:52 PM
Timothyj
Timothyj's Avatar
Thought about that, the fuse box was more in the way, hardest thing was getting the bulb to line up. I could move my hand o.k., to a point and got cramped. Still sore from it and my hands are not that big. Almost like going in blind to do this. sucks. Thanks for the tip, take care.
tim
Old 12-05-12, 03:53 PM
PuReChaos
PuReChaos's Avatar
As speedkar9 stated, removing the battery was what I did with my 2003 es. Once removed you'll have enough room to maneuver around on the driver side.
Old 12-05-12, 05:05 PM
speedkar9
speedkar9's Avatar
You could try using gloves to protect your hand from scaring against the fender liner/ rad cradle. I had to do that when swapping my parking lights to LED's. It was really tight in there.
Use a mirror to lineup the bulb, or practice on the passenger side where there's more room. See if taking the cover off the fuse box lends you a tiny bit of clearance.
Alternatively you could take the whole headlight assembly off...
Just peel the bumper around the corner, and remove ~3 bolts.
Old 12-06-12, 01:46 AM
Timothyj
Timothyj's Avatar
Thanks for the help. Hope these bulbs last a long time. Take care.
Old 04-11-13, 08:08 PM
Chocolate
Chocolate's Avatar
I was reading BenES300's thread on lighting and searched for some more information on those 194 parking lights. Were you able to change them without removing anything? I tried for a few minutes but couldn't gain access to the bulb, so I thought I'd ask here before going further. Thanks.
Old 04-12-13, 12:56 AM
Timothyj
Timothyj's Avatar
Yes i changed them without removing anything, just took way to long, had to walk away, took a deep breath and tried again and changed the bulb. Total pain in the ***. My thought was I'll try it, if i can't do it, then take somewhere and have it done. My local shop charged me $ 30-$35 to change one a few years ago. Stupid design. I just did it by feel and got lucky. Good luck, hope this helps.
Old 04-15-13, 09:11 PM
Chocolate
Chocolate's Avatar
Thanks. I will give it another try with some needle nose pliers. Do you remember which way each bulb socket needed to be torqued?
Old 04-16-13, 12:11 PM
Timothyj
Timothyj's Avatar
no I don't know, try looking at the bulb and the socket to see how it lines up.
lff
Lighting
08-28-17 11:09 AM
jnguyen87
Lighting
02-14-11 10:57 PM
ng123ray
ES - 5th Gen (2007-2012)
12
11-15-07 11:24 AM
lexus96817
11-08-07 12:13 PM
snboarder8
Lighting
15
10-29-04 04:24 PM
Quick Reply: changing low beam bulbs 04 es
