First Engine code..P1410..help!
Old 11-18-12, 08:43 PM
MrShim78
MrShim78's Avatar
Default First Engine code..P1410..help!
Hi Guys
so i did my first oil change and second pcv valve replacement over the weekend, felt pretty good about my DIY and today on sunday night the engine throws a code
now i dont know if its linked to the pcv valve or not.
the code is p1410 which means the egr valve sensor or something is shot. i looked up the codes, tried to find a tutorial or article here on it but to no avail.
is it easy enough to replace? the check engine light is now gone. it was on for about an hour, then went away. but the code is stored, i used my obd scanner and found it stored.
advice? shall i clear codes and wait for it to re appear? or shall i replace the sensor?
i also must mention. i get a very slight hesitation in first gear when i accelerate from a dead stop..happens alot of turns, i give it a bit more power and it goes away...
could this be related?
maybe i should reset my ecu and hope for the best? haha. no? ok then...
please help! would appreciate any thoughts/ideas. i am in cold canada and its getting colder, i cant have my car die on me
Old 11-19-12, 07:29 AM
PFB
PFB's Avatar
If it was my car, I would reset the codes from memory, and. See if they return. Did you use a Lexus PCV valve or an aftermarket?
Either way, it does not sound that your code is related to your DIY efforts.
Phil
Old 11-19-12, 07:35 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Reset and see if they come back, most likely not linked to your DIY's.
Old 11-20-12, 02:33 PM
MrShim78
MrShim78's Avatar
Thanks for the advice guys. I have cleared the codes. lets see if it comes back... ! will holler if it does...
Old 11-27-12, 09:08 PM
MrShim78
MrShim78's Avatar
hey guys, so its been a few days...and i took a 200 km trip once in the last week too...and no light
it has not come back! yet...its been about 350 km + since i cleared the code.
now..shall i run a scanner again? could it be stored again and the light not come on?
i'll check that..but no light so far....hmmmm...
Old 11-27-12, 09:10 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Wait for it.... BTW, you cannot pull any codes if the CEL isn't on.
Old 11-28-12, 04:05 PM
GS4_Fiend
GS4_Fiend's Avatar
The EGR pintle inside was probably stuck which caused the code P1410. If it comes on again, you need to verify if EGR is working.
Old 11-28-12, 05:15 PM
MrShim78
MrShim78's Avatar
thanks gs4_fiend. you mean the egr sensor right? replace or confirm that is working? (with the meter) ?
Old 11-29-12, 11:08 AM
GS4_Fiend
GS4_Fiend's Avatar
the egr and sensor comes in 1 piece IIRC. you need to remove the EGR and clean the pintle, if doesn't work you must replace. no choice.
Old 11-29-12, 12:16 PM
BDSL
BDSL's Avatar
The EGR valve position sensor is very easy to access...it is just right above the EGR valve.
When I replaced mine many many years ago, the part was only CAD$30-40 from the dealership.
Old 12-02-12, 08:46 PM
MrShim78
MrShim78's Avatar
Hi guys...so its baack! the code came back today. check engine light was on for a few hours then went off again. but the code is stored. same code.. p1410.
i guess this means i change out the egr valve position sensor....?
Old 12-02-12, 08:56 PM
MrShim78
MrShim78's Avatar
this sounds right..?
http://community.cartalk.com/discuss...ght-code-p1410
Old 12-03-12, 10:41 AM
BDSL
BDSL's Avatar
PM'ed you.
The EGR valve position sensor is a sensor with a triangular flange on top of the EGR valve.
It is just held down by 3 small fasteners. It takes 30 seconds to removed and another 30 seconds to install a new one.
Old 12-19-12, 10:16 PM
MrShim78
MrShim78's Avatar
Default updated on the p1410
Hi everyone. just an update. i know i may be taking this too far BUT..i followed the hanes+fsm and did a check and the resistance is 5 kilohm and the range should be 1-4.3 k ohm. so the sensor seems to be busted.. took it out, cleaned it (white goo was on it) but to no avail the light came back. so i have ordered a new sensor from rockauto ..should be here in a few days!!
. i also did a obd scan , pictures of freeze frame data attached. any idea why its running rich??
maybe i should not worry about it but it does seem to be running worse in terms of mpg... since the EGR sensor went bad...
Attached Thumbnails First Engine code..P1410..help!-ffdata-1.png   First Engine code..P1410..help!-fuel-trim-data.png
Old 12-27-12, 08:20 PM
MrShim78
MrShim78's Avatar
HI BDSL and everyone
I got the sensor, doing the replacement tonight. After the replacement, shall i reset the computer itself by taking off the negative batt terminal, or just clear the codes and let it be?
thanks
Originally Posted by BDSL
PM'ed you.
Quick Reply: First Engine code..P1410..help!
