HELP!! es300 mystery codes
Old 11-02-12, 07:52 AM
stopdrpnro
stopdrpnro's Avatar
Default HELP!! es300 mystery codes
got a deal (sorta ) on a 1999 es300. It bogs hard under acceleration and lacks the power to make it up a hill. been researching and replacing parts as I go here's what's been replaced
1.knock sensor
2.maf sensor
3.pcv valve
4. air filter&fuel filter
5. gas
6. spark plugs
7. bad coil pack
8. 02 sensor
swapped relays ,cleaned intake, tb, iac . ran seafoam and techron through. got it down to one lean code po171 .idles high even after being warm , i slam the gas and go from 1200rpm to 2k but no higher, until i let off a bit . here's a video of what it does. i'm at witts end HELLPPPPPPP
http://s21.beta.photobucket.com/user...02208.mp4.html
Old 11-03-12, 08:13 PM
Hayk
Hayk's Avatar
Sounds like restricted fuel delivery or weak spark. You need to check your fuel pressure at idle and fuel flow(harder to do). If anything, remove your fuel pump and inspect its filter and other related components that attach to that assembly.
Could you please list the manufacturers of each part that you replaced, and who did the labor?
Old 11-09-12, 01:22 PM
stopdrpnro
stopdrpnro's Avatar
all denso/oem parts doing the labor myself. replaced the tps and removed the ful pump and cleaned the built in filter with no change. took a better video
@17s I floor it
@31s I completely release accelerator
@37s I floor it again
@41s i release accelerator
@49s i very slowly press accelerator
@56s I release
@1m I slowly press acclerator
http://s21.beta.photobucket.com/user...22156.mp4.html
Old 11-09-12, 02:00 PM
MikeLex
MikeLex's Avatar
1.knock sensor
2.maf sensor
3.pcv valve
5. gas
6. spark plugs
7. bad coil pack
8. 02 sensor
Oil control valve should be in your list also. Typical issue for the first generation of VVT-i engines.
Old 11-13-12, 06:48 PM
stopdrpnro
stopdrpnro's Avatar
i think i'm looking in th wrong direction all together wouldn't all these senors trip codes if they were bad? could there be something bad mechanically that won't show up on the obd scanner?
tru2au
12-28-14 06:47 PM
BK4293
14
01-16-13 02:42 PM
DGIKULJOT
08-16-12 11:13 AM
lilninja
05-06-12 04:06 PM
jbriley3
04-12-12 12:48 PM
Quick Reply: HELP!! es300 mystery codes
