1996 es300 won't start. Trouble shooting with nothing yet, please help
Old 10-20-12, 12:00 AM
regorih
regorih's Avatar
Default 1996 es300 won't start. Trouble shooting with nothing yet, please help
Guys I really need your help on this one.
1996 Lexus es300 USA model but built in Japan with the 1mzfe engine.
Old symptoms- car would start but somes times I would have to wait ten minutes before it wanted to turn on and when it would turn on it would react late from the time I gave it gas to the point it started to accelerate and as I was going it would cut in and out.
I changed the starter and now it wont turn on.
This is all my trouble shooting.
- checked all the fuses and they where all good
- checked for CEL codes with the scanner and no codes
- checked fuel pump and it does pump gas when I turn the key to crank position
- checked fuel pressure after fuel filer and got @50psi from cranking
so at this point I try to turn the car on and it does but it idles around 400rpms and when I gave it throttle it would not exceed past 700rpms even at wide open throttle. Car turns off and still no CEL light or codes
Now I look at the spark plugs even though the car turned on. I find that the spark plugs are wet with gas and test to see if the spark plugs in the coil boot are firing, well I see no spark arc.
I get my multimeter and put the key in the ignition and turn it to start and check for 12 volts at the coil connector, well I get 0 volts.
I repeat the process again but this time with some one cranking the car and I still get 0 volts at the coil connector pins.
So my questions is what controls voltage being supplies to the coils?
Super desperate
Any tips would make the world
Roger
Old 10-20-12, 06:22 AM
hzt30
hzt30's Avatar
You should have 12 volts on pin #1 of the coils with the ignition on. The 12 volts comes from the ignition switch.
Old 10-20-12, 08:27 AM
regorih
regorih's Avatar
Can you specify where pin 1 is exactly at ?
Old 10-20-12, 09:30 AM
hzt30
hzt30's Avatar
Pin #1 has a wire that is black with a red tracer. Pin #2 is a blue wire that comes from the igniter.
Old 10-20-12, 10:09 AM
hzt30
hzt30's Avatar
This is the picture of the DIS ignition system for a 1997 ES300... one coil for two spark plugs.
Old 10-21-12, 07:46 AM
regorih
regorih's Avatar
hzt30,
Thank you so much for the help but to be honest im not on that level yet. I have taken a electrical class for drafting a white back so the diagram is not totally alien to me, although I will say im some what lost.
If you could walk me through the process it would help out. Im assuming pin one is coil No.1? Just in case I dont get 12v with the ignition on one do I just keep going back?
Im also not sure where pin 2 is.
So should I have 12v by checking pin 1 and pin 2? \
I am familiar with a multimeter as far as checking for voltage, continuity, and resistance.
Roger
Old 10-21-12, 04:37 PM
regorih
regorih's Avatar
hzt30,
Ok I studies the diagram and I understand it now.
With the ignition on I did get a reading of 12v at pin 1 from all three coils when I grounded the circuit with the multimeter.
Now with the ignition on I got a reading of .20v from pin 2 on all three coils.
Can this mean the igniter is bad? Maybe I could test it, is there a way to do that?
Roger
Old 10-21-12, 04:42 PM
regorih
regorih's Avatar
I did want to add that I also got a reading of 12v from the black wire with red tracer that is a #9 that travels after the J22 junction connection that's leads to the igniter.
Old 10-22-12, 08:31 AM
hzt30
hzt30's Avatar
You should get 12 Volts on the black w/red tracer with ignition on. This is your ignition feed which goes to pin #1 of the three coils. Pin #2 of the coils come from the igniter which is a pulse signal when the engine is cranking or running. If you get no pulses on pin #2 of the coils, then the igniter is not sending it out. This could be a problem with the crank sensor telling the ECM not to send a trigger to the igniter.
EddieKat
12
08-31-15 04:29 AM
apoxc69
12-13-11 05:46 PM
SidewaysGS
GS - 1st Gen (1993-1997)
07-19-09 12:43 PM
MR2-Mike
01-18-09 10:32 PM
phild
18
09-04-08 07:26 PM
Quick Reply: 1996 es300 won't start. Trouble shooting with nothing yet, please help
