Problem with my ES300 2002 , trac. Off and vsc. Light
Old 10-15-12, 10:45 AM
lmontes
lmontes's Avatar
Default Problem with my ES300 2002 , trac. Off and vsc. Light
I changed my timing belt on my Lexus 2002 ES300
The check engine light and trac. Off and vsc. Came on. The code P1346 came up . I had to re-install the belt two more times , the third time I finally put it on correctly . The check engine light does not come on any more . The trac off and vsc still come on. These lights have never come on until I changed the timing belt the first time. Does any one know how to calibrate my Lexus so I can remove the trac off and vsc?
Old 10-15-12, 05:57 PM
hzt30
hzt30's Avatar
You need to do a zero point calibration. This video is done on a Scion but they say it is the same on Lexus, Toyota.
Here is the official Toyota procedure that worked on a 2002 ES300. The procedure is near the end of the document:
http://www.toyota-4runner.org/attach...-dtc-c1203.pdf
xxx
Patsum
03-26-12 07:51 AM
evo23
10-28-11 03:17 PM
acc
07-09-10 12:52 PM
tanvet
04-28-09 05:42 AM
vinny11
04-12-09 08:18 AM
Quick Reply: Problem with my ES300 2002 , trac. Off and vsc. Light
