Timing Belt Questions
Old 04-11-13, 09:57 AM
moonphase
moonphase's Avatar
Originally Posted by rolo1985
can anyone send me a PDF or a link where I can see the timing marks location on the both cams and the crank and how they line up. PLEASE
THANKS again for your replies back
when you get a new belt, the marks are on the new belt that line up with engine timing marks. If you are re-using an old belt where the marks are worn off, you are supposed to mark the belt before removal.
Old 04-11-13, 12:19 PM
msekanha
msekanha's Avatar
Double check your timing marks on the crankshaft. There are two marks on the crankshaft, one mark is for the oil pump and the other is for the back timing cover. I've nade the mistake of mixing up these marks and thank god the 97 is a non-interference.
jjrose9
GX - 1st Gen (2004-2009)
09-16-10 06:05 PM
driftway
04-01-09 03:04 PM
JMny2004
10-09-05 05:29 PM
richma7175
08-05-05 02:51 PM
ES3
Maintenance
11-25-02 04:26 PM
Quick Reply: Timing Belt Questions
