Front Suspension Help
Hi,
I just replaced the front struts, lower and upper isolators, and upper mount with new bearings. Now whenever I'm at a low speed and make a sharp turn I hear a popping noise from front. (boh sides will make the noise depending on which way I turn) This doesn't happen all the time but it's annoying. I didn't put grease on the upper isolators when I installed them, do you think that might be an issue. I read that grease needed to be added after I already installed the struts. PLEASE HELP!
