1998 Lexus es 300
1998 Lexus es 300
Hi all,
I need a good idea where my sensors are for both the up stream ones and downstream. Does the two up stream use the same a/f sensor for 98 es 300 and where are they located????
B2S1 is by the radiator, next to the transmission dipstick. B1S1 is underneath the car next to the Steering Rack, very hard to get to. I just replaced both so let me know if you need help.
Another thing to keep in mind is that you have to find out if your car is California Emissions Certified or not. California Emission cars use Air/Fuel Sensors, while Non-CA cars use Oxygen sensors - they look and function differently.
I thought the 1998 does use an air-fuel ratio sensor, just a different one for Cali spec. But yes the part numbers are different for some reason but the units AFAIK are identical front and back bank.
What I'm getting at is that if your 1998 ES300 has an emissions sticker on the underside of the hood that says CA, then buy the Denso 234-9009 for your upstream sensors. If not, then get the 234-4622
You can also email Sewell Lexus your VIN number and they'll tell you if your car needs California sensors.
p.s.: The Toyota part numbers are different because the wire length is not the same. What's absurd is that Toyota has a different price for each one. If you buy the Denso sensors, the wire is a little longer, but it fits just fine.
