Clunk Noise
Old 06-30-12, 11:21 PM
RXGS
RXGS's Avatar
Default Clunk Noise
As some of you know, i just got my transmission replaced. Now every once in a while i hear a single clunk coming from the left front wheel. It doesn't clunk when im driving along, but it does when i turn the wheel suddenly to the right. It also makes the noise if the car is off and i move the steering wheel there is a clunk type noise. Anyone have any ideas? It also happens when backing out of the driveway turning the wheel then accelerating forward. It is a single clunk noise, not multiple. Any help would be appreciated.
Old 06-30-12, 11:28 PM
RXGS
RXGS's Avatar
I forgot to add if the wheel is jacked up, it doesn't make a noise. I also put my hands at 12 and 6 and 9 and 3 and there was no movement.
Old 07-31-15, 05:53 PM
hanamannie
hanamannie's Avatar
Default Clunking noise
I have same exact problem on my 2001 LS430 with 85,000 miles and my mechanic was unable to determine what causes the noise. I would appreciate any help to fix this problem
Old 08-01-15, 12:14 PM
RXGS
RXGS's Avatar
Was not expecting to find this. If I rember correctly, the noise did go away and if I remember correctly it was something with the brake pads hitting the rotor
Old 08-01-15, 12:57 PM
hanamannie
hanamannie's Avatar
Problem solved:
Here's a link to fix this problem
DIY 01 LS430 Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise front
https://www.clublexus.com/forums/ls-...ise-front.html
Old 08-01-15, 05:10 PM
hanamannie
hanamannie's Avatar
Thanks, here’s a link of the noise problem that you had posted
https://www.clublexus.com/forums/sus...balljoint.html
Old 08-01-15, 06:25 PM
RXGS
RXGS's Avatar
Ah that was a different noise on a different car haha, I'm unlucky i guess, but that could have be it as well.
173rd
12-09-22 05:26 AM
Behemoth7
12-02-14 10:34 PM
right RX
RX - 1st Gen (1999-2003)
02-14-06 02:01 PM
TMaxxTim
Suspension and Brakes
04-07-05 01:25 PM
Quick Reply: Clunk Noise
