i would like to use the "flash " approach and recieve my own trouble codes on my 1994 es300.
there is a box attached to my intake with the word diagnosis and a cluster of 9 ports and 2 then another cluster of 6 then 3 and 3 more but i have no idea which to jump with a wire nor do i have a list of codes to compare after writing the sequence of flashes of the CEl
'94+ ES's are OBD2. You HAVE to use the scanner with using the cars OBD2 port to get the CEL codes. The DLC (Data Link Connector, Diag) you can use for the ABS, SRS, Cruise, etc codes by counting flashes, but not the CEL.
i do not have a scanner and the only one i have access to is only for 2003+ so i figured id try the flash method and nothing showed... just solid cel with key on and eng. not running. i was wondering why i had no cel before now and took speedo out and switched bulb with the OD off one and now have cel so maybe drive it to autozone. allthough i know it is obd2 i have no access to one that is compatible with the year.
Huh? OBD2 readers are universal. There is NO reason it shouldn't work on yours if it works on an 03. I;ve used at LEAST 10 diff OBD2 scanners on my '96, and not once had one not work.
well he said he would need a diff connector for lexus and he cannot find one for his scanner on ebay or amazon i think his scanner software is obsolete or something. he has a generic one from napa
Your mechanics probably couldnt find the OBD 2 connector. Open the fuse cover on the left side of the steering wheel.
