Rattle sound after rotating tires
Old 04-17-12, 05:52 AM
Joey97
Joey97's Avatar
Default Rattle sound after rotating tires
Im getting a rattle sound from the front going over bumps since i rotated the tires. Never heard the rattle before. What should i check ?
Old 04-17-12, 05:56 AM
BDSL
BDSL's Avatar
Loose wheel???
Things to check:
- damaged brake shield
- ball joint
- tie rod
- sway bar end link and bushing
- strut mount
Old 04-17-12, 06:06 AM
Joey97
Joey97's Avatar
What about a loose center cap ? Just wierd that it started after i rotated the tires..
Old 04-17-12, 08:21 AM
smee
smee's Avatar
I had loose center caps for the longest time before I realized what the sound was coming from.
Take out the center cap(s), bend the little tab things which hold the cap in place (when it's pushed into the wheel) so that there will be more tension.
If that doesn't fix it, check the list above:
Old 04-17-12, 09:19 AM
Joey97
Joey97's Avatar
Were you able to move the center cap by hand while the wheel was still on the car ?
Old 04-17-12, 09:34 AM
Hayk
Hayk's Avatar
Retorque the lug nuts to be safe.
Old 04-17-12, 07:49 PM
Joey97
Joey97's Avatar
When I drove home from work I did not hear the rattle anymore
Old 04-17-12, 08:24 PM
Bankos66
Bankos66's Avatar
I have a clicking noise coming from tires. Ticks faster when speed is higher. No idea what it is
Old 04-21-12, 06:42 AM
pauloil
pauloil's Avatar
+1
I always check my lug nuts about a week after rotation or tire work: 80 ft lbs
Old 04-21-12, 04:01 PM
Hayk
Hayk's Avatar
Originally Posted by pauloil
+1
Ever since I bought a torque wrench, I've been so **** about tightening the lug nuts to the right specs. I looked in the manual, and if I recall correctly, they ask for about 76ft lbs. So to make it easier to remember, I set them to 77.
Every time that I've had to work on a car that came from a mechanic, I've noticed just how much more they torque them, probably with an impact gun. At least they're nice enough not to do it on the locks. Which I think is even worse, because the whole point of using the same torque on each lug nut, is to evenly distribute the pressure of the wheel onto the brake rotors/hubs. If you do it unevenly, you're risking warping the brake rotors.
joe diego
Wheels, Tires & Brakes Forum
01-18-19 06:15 AM
twin703
07-19-16 06:45 PM
MikeyK02
05-16-14 08:20 PM
Quick Reply: Rattle sound after rotating tires
