Rear Brakes
Old 03-07-12, 10:36 PM
RXGS
RXGS's Avatar
Question Rear Brakes
So today while driving my car (first time in a few weeks) i heard a squeaking noise when braking from the rear, no big deal i guess. Later one the caliper seemed to stick and the car was getting harder to move. I pressed on the brake a few times and it seemed to work and the caliper didn't stick or seem to stick as much. I drove home and i hear a POP noise and then a constant grinding. Now even when parked, the car makes a loud squeaking noise if moved at all. Any ideas? I am not driving the car and just ordered new calipers, rotors, and pads. Is my caliper completely done or is it just the pads? The outside one looks fine so maybe it is just the inside pad? The car doesn't seem to be vibrating while braking just a loud squeaking/grinding noise while driving. What worries me most was the pop noise. I ended up buying 2 Remanufactured napa brake calipers and Premium Rotors (much cheaper then Ultra Premium). Does anyone have any ideas? I just want to make sure it's not something worse. Can brakes go so badly so quickly? Everything seems to go wrong at once.
Old 03-08-12, 06:07 AM
01LEXPL
01LEXPL's Avatar
That's weird. Maybe try and bleed the system, could be air bubbles...
I just changed my caliper and its running great now. Rear brakes only have about 20% of braking power, so it wouldn't stop the car.
Drive on it for a bit if its been sitting around for a while... Touch the rim after a spirited drive, if its warm compared to the others, the caliper is sticking, you can also smell the burning pad material.
Old 03-08-12, 06:41 AM
RXGS
RXGS's Avatar
I couldn't get napa parts so i had to settle for advance auto fenco calipers and wereweaver? rotors and pads. All have warranties so i am not to worried, i needed to settle because i am leaving for cleveland Saturday and no one besides Advance had parts in stock. I regreased the pins on the rear calipers last summer so i think they finally had it after 180k miles and 11 years
Old 03-08-12, 04:21 PM
RXGS
RXGS's Avatar
I looked again, it turns out that just the inside of the left rear rotor is grinding, but not the outside? Needless to say i think i will just change everything as the rear calipers are original
Old 03-08-12, 06:25 PM
hypervish
hypervish's Avatar
I think the OEM calipers are better than the rebuilt crap sold at Advanced Auto Parts or any chain parts store. I suggest returning the calipers, and just keeping the original's on if they aren't bad.
Old 03-08-12, 06:55 PM
01LEXPL
01LEXPL's Avatar
^ and they're also 300$ a corner, no thanks, especially not on a decade old car...
And you do know that the 'rebuilt crap' is simply sold by some third party but is OEM, right?
Old 03-08-12, 07:31 PM
03 ES
03 ES's Avatar
locked caliper or seized caliper slides.
or even more simply, very worn brake pads.
Old 03-08-12, 10:38 PM
RXGS
RXGS's Avatar
The rotors were definitely done, i knew that before hand, and for the rear brakes, i am not paying that much for OEM parts. Plus with a lifetime warranty i am very content
Old 03-09-12, 03:40 AM
hypervish
hypervish's Avatar
You do realize that the parts that came with the car are OE, not OEM.
Also, the rebuilt crap is not rebuilt by the OE company, it's rebuilt by some "joe blogg" who doesn't know the first thing about rebuilding a caliper. I've seen tons of these fail, it's better to get it from Sewell or some other website.
The decade old calipers will last much longer that these crappy rebuilt calipers, but to each his own.
Old 03-09-12, 06:01 AM
RXGS
RXGS's Avatar
I am not to worried as there is a lifetime aarranty and labor doesn't cost me much at all
Old 03-09-12, 08:03 AM
01LEXPL
01LEXPL's Avatar
You are so dense. It's sad.
Aisin makes these for Toyota, I'd call that oem since it came off the production line on the car. They use the same components to rebuild these for re-use. They are cleaned and done properly, like a NIB caliper from Toyota.
Fact of the matter is, OEM caliper fail, this is the second I've had fail on my car since I've had it in 6 years or so. Both original that had to be replaced.
Old 03-09-12, 01:55 PM
hypervish
hypervish's Avatar
The parts that are on the car when it comes off the assembly line are OE. Meaning "Original Equipment", not OEM which is "Original Equipment Manufacture".
I still stand by what I said originally, and will agree to disagree about rebuilt calipers.
Old 03-25-12, 01:23 PM
xsh0tya
xsh0tya's Avatar
I just got my rear break pads and rotors done this weekend. I got Brembo Rotors and pads all through the dealership. I paid 100 for the rotors and 65 for the pads thanks to my friend. How much if you don't mind me asking did your rotors and pads cost?
Old 03-25-12, 05:45 PM
RXGS
RXGS's Avatar
Rotors cost me 30 a piece, pads i think i paid 40 for the 4 rear ones, then 97 for the calipers. I just wanted something that would cope with everyday driving, im not a spirited driver by any means so replacing it was the main priority.
Old 03-25-12, 11:12 PM
xsh0tya
xsh0tya's Avatar
Okay so I wasn't overpaying. I am pretty hard on my brakes so I can't complain.
badteddy
Suspension and Brakes
09-16-14 09:20 AM
magius231
08-25-10 10:55 AM
truenoboy
21
07-20-10 03:19 PM
Farino81
05-10-09 10:09 PM
calichris
09-05-07 06:45 PM
Quick Reply: Rear Brakes
