Rear main seal
Old 03-03-12, 02:58 PM
mitmaks
mitmaks's Avatar
Default Rear main seal
Looks like rear main is leaking. Should I tackle this myself, anyone here done this before?
Old 03-03-12, 03:03 PM
ES3_Ray
ES3_Ray's Avatar
if you can pull out an engine, go for it.
when you pull it out, make sure you dont take all the sensors off the engine, rather unplug the ecu from behind the glovebox and pull the plugs through to the engine bay. also use impact when taking off the exhaust pipes. make sure you have high temp rtv on hand as well.
have fun.
Old 03-03-12, 03:07 PM
PFB
PFB's Avatar
What year and model are you talking about? Did my 2001 es300 a few monts ago by the local Lexus dealer. Transmission needs to come out, engine does not.
Do a search, you'll find my post, comments and costs on this repair.
Phil
Old 03-03-12, 04:12 PM
hypervish
hypervish's Avatar
First try Auto-RX, it's worked for many people in curing the rear main seal leak. It's not a guaranteed fix, but I think it's worth a shot.
Old 03-03-12, 05:57 PM
mitmaks
mitmaks's Avatar
Tranny definitely needs to come out, that's what I've read so far. I've tried Bar's rear main leak seal but so far it hasn't worked and I hate oil stains on my driveway.
Old 03-12-12, 10:18 PM
RXGS
RXGS's Avatar
Anyone try auto-rx with this. The place said it was the oil pan, but when i looked it seemed to be the rear main seal
Old 03-13-12, 12:59 PM
mitmaks
mitmaks's Avatar
Even if it does work, it will only be temporary. Our Lexus has ~180,000 on it and I'm sure old seal is pretty much disintegrated in there.
Old 03-13-12, 01:17 PM
RXGS
RXGS's Avatar
I have 182k miles, its hard to swallow a 900 dollar fix for a small oil leak
Old 03-13-12, 01:44 PM
hypervish
hypervish's Avatar
Try the AutoRX, if it's a rear main seal, it's worked for many people. It doesn't cost much, so what's the harm. lol
Old 03-16-12, 11:31 AM
mitmaks
mitmaks's Avatar
My mechanic would do it for $385
draco
01-18-17 03:37 AM
AntzCro
08-31-12 08:39 PM
golfdawg
13
05-18-12 07:24 AM
kennyn90
04-30-09 12:02 PM
Quick Reply: Rear main seal
