96 ES300 smog test fail
Old 02-17-12, 07:38 PM
texcorndog
texcorndog's Avatar
I had a similar problem. Failed ac 2x in BC before I figured it out.
I had tho replaced the cat & cracked y pipe. Still failed.
Had 2 new o2 sensors installed, still failed
The problem I had was fuel injector leaks. A mechanic I used installed the o rings wrong ( yea can u believe that ?) plus he used the wrong size gaskets on 2 inj too, so the rail was not seating properly & the air fuel mixture was all screwed up.
So Id check your fuel system & vacumn leaks.
Intake air gasket problem maybe?
Cracked MAF hose?
Old 03-06-12, 12:28 AM
Mxkmster
Mxkmster's Avatar
I just had mine smog a few days ago and from what yours looks like I would check the timing first. If the timing isnt around 10 degrees btdc . Where you emission levels are at you also might need spark plugs. A new cat willn't fix your problem. If you are in the Orange county area I could help you out
Lveyolfe
10-03-17 07:07 PM
leggman1
05-31-15 11:51 AM
someguy85
11-08-11 04:45 PM
2001ES300
11-05-07 10:15 PM
Quick Reply: 96 ES300 smog test fail
