if you remove battery !!!!read
Old 01-22-12, 09:25 PM
johndeez
johndeez's Avatar
Default if you remove battery !!!!read
so yesterday i removed the battery to install my hid kit ...after i was done my car kept dieing
it was idleing at around 200 rpm ...
solution !!!!!!!!!!!!!!!!!!!!!
please listen ....start car and idle car at 1000rpm for about 10 min !
then drive car for 30 min
follow by idle for about 5 min more ...tata your done your ecu must relearn the rpm
was told by lexus mechanic.....i laughed when he told me ...till i tried it and worked...wow
your welcome
1MZ (12-16-22)
Old 01-22-12, 09:37 PM
orion603
orion603's Avatar
hm, I recently removed my battery to install GROM iPod adapter but had no issue like that. I guess I was lucky?
Old 01-22-12, 09:44 PM
ASG14
ASG14's Avatar
It will idle low but shouldn't die. Really really weird.
Old 01-23-12, 10:22 AM
Rollin'ES3
Rollin'ES3's Avatar
hmm. thats odd. When I owned my ES300 I never ran into that problem...
Old 01-23-12, 10:37 AM
01LEXPL
01LEXPL's Avatar
that's not supposed to happen... the only thing that occurs when you remove the battery is losing your seat presets...
Old 01-23-12, 10:56 AM
BDSL
BDSL's Avatar
I changed my battery 3 weeks ago. The seat memory was not erased. The radio station program was not erased. The clock was not reset. There was no change in idling speed.
Old 01-23-12, 08:51 PM
GS4_Fiend
GS4_Fiend's Avatar
Your a fast changer. Leave it off any longer you will lose all.
Old 01-23-12, 09:47 PM
Hayk
Hayk's Avatar
When I bought my car, I removed the battery to clean off corrosion. I forget how long I had it out of the car for, but it was definitely more than a few hours. I then put it back in and had the negative cable disconnected for at least a few weeks. This was while I was repairing the valve cover seals. When I finally got to start it up for the first time, the car ran great with no idling issues.
Old 01-23-12, 10:14 PM
Yurka
Yurka's Avatar
i just installed hid kit for fog lights few hours ago, thx god cars running good, no issues
Old 01-26-12, 02:56 AM
marcoes300
marcoes300's Avatar
never did that to me ... and i unpluged/pluged my battery so many times
Old 01-29-12, 02:08 AM
paperboy42
paperboy42's Avatar
i installed an hid kit on my friend's 95 ES without disconnecting the battery.... kinda hard to cause a short circuit with something as simple as HIDs
Old 09-27-14, 07:48 PM
pogijeffre
pogijeffre's Avatar
That just happened to me... I'm about to do that process. Hopefully it works
Old 12-16-22, 07:23 AM
1MZ
10th Gear
1MZ's Avatar
your welcome
I had the same issues and this worked to FIX
lexag12
12-06-15 07:33 AM
Solo2
12
12-02-12 10:23 AM
bigbriman
GX - 1st Gen (2004-2009)
10-29-10 09:25 PM
Dave Zorychta
10-05-01 04:34 AM
Dave Zorychta
10-02-01 07:55 AM
Quick Reply: if you remove battery !!!!read
