97 ES300 Rear Shocks Replacement.
I found some great prices on rear shock assemblies at Rockauto.com...
My question is what else do I need? Upper mounts and spring isolators? Car has 136k miles and i know for a fact the rear shocks are shot. I'd like to get all the parts and then just pay labor for the installation... Thanks
Where in S FL are you?
I'd def replace the mounts with the struts. I would personally use KYB brand if you want stock ride with quality. The stock struts are actually made by KYB. The upper insolators are part of the mount. the lower one I would only replace if they need to be. See if they are still nicely intact are cracking up and falling apart.
The only other thing would be the sway bar bushings and links. The bushings, IF original, I would replace for sure. The links only is they have to be cut off. But being in FL, chances are decent that they will come off ok since there isn;t as much rust as up here in the north.
Are you buying just struts? Or the 'quickstruts' ?
I have the whole set on mine i just did. Drives better than before. Cost me ~540$ ish shipped. From www.rockauto.com
Monroe quickstruts - the whole deal. Didn't want to waste time with individual components only to pay the mechanicn in labor where i would think i'm 'saving' money in not getting new springs...
LOL! Yes, Durrby (Mike), 2 years ago I drove his SC fromt he CL meet in Orlando down to Ft. L with him. Was a fun drive.
And yes, you are correct.
Strut Mounts x 2: KYB Part # SM5175
Right Rear Strut: KYB Part # 334133
Left Rear Strut: KYB Part # 334134
I'm actually coming down that wat this week.
That is correct- you need to order two. They only show one part number- as its the same for either side(rear only). The reason why there are two #'s for front- is because they are side-specific.
Chris
Chris
BillitZky
03-04-16 11:16 AM
