repeated coil failure in 2000 lexus es 300
Old 12-28-11, 02:12 PM
shoover
shoover's Avatar
Originally Posted by BradTank
I think there's something more going on, I have a hard time believing that many coils are failing on their own. Maybe a bad grounding issue? Are there any other electrical issues? How are you making sure the coils have actually gone bad? One way to check is to swap the coils around and see if the failure follows it.
These type of coils are certainly not a regular "disposable" part like spark plugs that you normally just throw away after a certain amount of mileage. Going through 8 coils in a short amount of time is very suspect.
Also, I would echo the sentiment that if money is really tight, go get some replacements at a salvage yard rather than aftermarket. This is one of those cases where OEM is really better. Sewell is a good online dealer where you can get factory parts for substantially less.
no other electrical issues besides the spark plugs only lasting 15,000 miles. the code did follow the coil when it was switched from #2 to #4. i trust the mechanic who does my work.
i wonder if tight valves; dirty fuel injectors; or something else is causing the spark plug and engine coil failure????!
gserrano80
05-31-16 03:50 PM
HtownBlue
12-23-12 12:01 PM
gorm2
08-12-12 11:06 PM
bluebug
RX - 1st Gen (1999-2003)
04-02-12 11:59 AM
5ltrbeater
02-18-08 03:57 PM
Quick Reply: repeated coil failure in 2000 lexus es 300
