fuel cleaner and oil
Old 11-21-11, 07:43 PM
coachwalk
coachwalk's Avatar
Default fuel cleaner and oil
Hey, all,
Should I use a fuel cleaner for my ES300? If so, what kind? Also, should I use synthetic oil since I have over 150k miles?
Thanks.
Old 11-21-11, 10:06 PM
worldforgo
worldforgo's Avatar
Everything I have heard is that Toyota actually suggests to not use Fuel Injector cleaner. I do however use Ethanol treatment as I have seen what it does to motors.
Old 11-21-11, 10:50 PM
EEngineer
EEngineer's Avatar
seafoam it and run premium for a tank or two.
and always use synthetic when you can. doesn't cost much nowadays anyway
Old 11-21-11, 11:47 PM
DRACO A5OG
DRACO A5OG's Avatar
I would say do not add fuel system cleaner if you have the OEM Fuel Pressure Regulator. Ask me how I know :eek:
If you feel you need to use fuel systems cleaner and can find it locate BG44K, it is Techron on steroids. But like I wrote, take care it may clean too well.
My local Toyota dealer's parts department recommend I use 10w30 Conventional. But it depends on your climate, I use to use synth but always had leaks, I swapped to conventional 10w30 Toyota brand and the leaks stopped. She seems to be quieter and smoother to boot
Old 11-22-11, 08:39 AM
01LEXPL
01LEXPL's Avatar
I've ran injector cleaner a couple of times.
Other than that, i'll get some octane booster once in a while.
Seafoam is great!
actright
ES - 6th Gen (2013-2018)
37
02-27-19 04:52 PM
animefreak
Maintenance
59
06-30-08 03:11 AM
finetune00
03-28-06 02:23 PM
persian451
20
08-12-03 07:07 PM
Quick Reply: fuel cleaner and oil
