2001 ES300 won't start
Old 05-16-11, 10:39 AM
GoTigersGo
GoTigersGo's Avatar
Default 2001 ES300 won't start
When I turn the key, I hear click click click over and over really fast. All lights and electronics worked. Didn't think it was battery, but tried jumping anyway to no avail. Any suggestions?
Old 05-16-11, 11:10 AM
GoTigersGo
GoTigersGo's Avatar
I've pulled the starter off and am taking it to Advanced for a test. Hopefully that is the problem. While I am doing so, you're suggestions are welcome.
Old 05-16-11, 12:53 PM
GoTigersGo
GoTigersGo's Avatar
Thanks for the help everyone. It turns out it was the battery and it wouldn't jump.
Old 05-17-11, 05:31 AM
BDSL
BDSL's Avatar
With a bad battery, you should still able to jump start the car.....and the engine would still run with a bad battery.
Old 05-17-11, 05:33 AM
worldforgo
worldforgo's Avatar
Sounds like you may have more of an issue than the battery. Unless you had the wires crossed while jumping the car...
Old 05-18-11, 08:40 AM
jskwik
jskwik's Avatar
see it all the time....bad connection....bad jumper cables...ect..the best way is to check for spark...also leave the cables for 5 min or so before trying to jump the vehicle..Glad u solved ur problem sorry u had to remove the starter!!! bad starter usually give one click..
Hsafe67
09-02-18 11:20 AM
MCVES300
07-15-18 11:06 PM
swyatt78
08-13-13 09:53 AM
lexxygirl
08-15-10 02:04 PM
shaitaan
Performance & Maintenance
06-21-06 09:41 PM
Quick Reply: 2001 ES300 won't start
