sterring wheel shaking at 110km/h
hi guys , my sterring wheel shaking ( w/o making noise) around 100-120 km/h. what do you think is causing that ? i cheked my rims and everythings ok ... i don't want to have a accident if something in the direction broke.
is it comon trouble for a 98 es 300 ( 160 k kilo) ?
tanks guys
tanks guys
^Wheel balancing is where I'd start but it could be something like a seized brake caliper, warped rotors, out-of-round tires (if the car sat without moving for a long period of time).
My vote is wheel(s) out of balance. Especially if you have weights that are stuck on the inside of the rim, as opposed to the ones that crimp on the outside. Either way, look closely for spot that is 'cleaner' than the surrounding part, where a weight has fallen off.
I knocked one off the inside while changing to summer rims just last week. Luckily I noticed and cemented the 2 weights back on. I'd be into the wheel shop next fall otherwise, paying for an expensive re-balance all round, since they'd have no way of telling which one(s) were off.
BTW, if your steering wheel is shaking, it's likely one or both of the fronts. If it was the rear, it often shows up as a vibration in the brake pedal.
tanks guys for all your comment , very helpfull , a other thing is when i brake , the car brake but like not normally more like doing ''wave'' do this is due to the unbalancement of my rims ?
well have the car get alingment,balanced ..and while they are at it ask them to have a look at the brakes pads and rotors. once they fix it then hopefully you wont be worried hehe
ok guys im coming back from my garage and they told me it was a brake probleme cause my front left brake was always on ... 435 to fix both side they changed ( idk how to say in english etrier de frein) and they trimmed my front disk ( bought 3 weeks ago -__-) cause with the brake on , they overheated .
but idk what caused that
Brake piston can seize on several factors:
- contaminated brake fluid
- broken / leaking piston seal
To avoid brake piston failure, one should bleed the brake fluid once every few years.
no . the other time i completly lost my right rims... and was a expensive fix ! but i think someone tryed to stole my new winter tire ... cause i dont see what happened excepted this ...
they remplaced the brake but .... is it normal that my pedal go very low comparated to when it was '' defective '' 6
sorry for my bad english lol
