Do this fit on my lexus es300 97?
I heard some parts from camry 97 can fit on the lexus idk is this...
http://cgi.ebay.com/ebaymotors/97-99...Q5fAccessories
i dont see why. doesnt has high/DRL lights as separate. So u will have to play around. But u should email the seller for dimensions. The side marker lights should def fit i would say. But too pricey tho
The price is for all four and that is definately a great price. One headlight from Depo on my ES was $150.00. But, I dont think the headlights will work, the top doesnt have the correct slope and will hit the hood and the mounting points are different from what I can see. The sides might work, but then I noticed the front clear lens of the corners bulges forward, which matches the headlights. If you cant get the headlights in then the lines of the corners wont match. Also, the bulb is a high and low, the ES is wired seperately, you would have to modifiy the wiring to get them to work. Seems like you would have to do a lot of work (customizing) to get them to fit and work, but it could be done. Its all up to you bro. Just know this is not a plug and play type of upgrade. Good luck!
He's being completely serious, not even NASA would be able to discern the difference.
I hope he is being sarcastic. The corners might work, but headlights, no way. As you can see, the slope of the ES head light is like around 45 degrees and the Camry one is like 60 degrees. Also, the mounting points are different on top and the sides. The ES has two mounting screws on the side as pictured and the Camry has one, from what I can tell. But like I said before, with lots of body work (customizing) you can get anything to work.
I purchased my Depo Headlights off a local seller on eBay, got them for just under $300.00 for both headlights.
doyounoem
01-31-15 01:14 PM
hammer88
05-19-04 09:42 PM
