How Many O2 Sensors?
Old 04-03-11, 04:31 PM
worldforgo
worldforgo's Avatar
Default How Many O2 Sensors?
I have a 1994 ES300. I need to replace Sensor 1 Bank 1 and Bank 2. From what I here the 93 only has two sensors, but does the 94 have the third sensor at the Cat or not? Any help appreciated!
Old 04-06-11, 01:03 PM
worldforgo
worldforgo's Avatar
Bump. Anyone got an ideas on the number?
Old 04-06-11, 04:10 PM
donbryce
donbryce's Avatar
Easy enough to check...just look underneath and if the 3rd one is there, you'll see it just aft of the cat. It would be threaded into a bung on the tailpipe.
Old 04-06-11, 05:08 PM
brandoe91
brandoe91's Avatar
This applies to 92-96 Es300 & Camry v6's (fed. spec)
92-93 3vz-fe
2 Upstream o2 sensors (front exhaust manifold and firewall side exhaust manifold)
94-96 1mz-fe
1 Downstream o2 sensor (post cat)
Source : http://www.densoaftermarket.com/cata....php?part=o2sn
Note: This question has been asked numerous times.. please use the search feature.
Old 04-06-11, 05:26 PM
Ls430es300
Ls430es300's Avatar
its connected to the exhaust pipe in between the exhaust and resonator
Old 11-05-14, 06:27 AM
GMIZZY
GMIZZY's Avatar
Which bank is obd1 code 25 and 26 on a 1993 lexus es 300
zajacjoe
05-14-18 10:14 AM
JoeBlob
Performance & Maintenance
02-08-18 08:12 PM
ISFpat
08-29-13 02:03 PM
geoprz
08-26-13 05:52 AM
inkredible
04-01-13 05:18 AM
Quick Reply: How Many O2 Sensors?
