Old 12-16-14, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
bad oxygen sensor, can i ignore it?
Old 02-24-11, 07:30 PM
ayroman
ayroman's Avatar
Originally Posted by snowmaker
you really should get a FSM online...they are free if you look
can you pls specify what FSM stands for/ what it is?
i wish i knew abt cars a bit more. thx
Old 02-24-11, 07:51 PM
88Legend
88Legend's Avatar
It stands for factory service manual.
Old 02-25-11, 05:25 PM
snowmaker
snowmaker's Avatar
fix the sensor..About $175 OEM.....Front is about 10 minutes...rear is about 25...
Old 02-26-11, 11:27 AM
tomf
tomf's Avatar
Originally Posted by AndyG
According to the Denso website you need 234-4622 which is the part to which you linked.
Old 03-25-11, 05:39 PM
ayroman
ayroman's Avatar
Originally Posted by tomf
no indicated sensor is Bank 2, Sensor 1.
thank you for your reply, i have finally bought a DENSO sensor, i found its locatins at the firewall, and about to change it myself.
But what do you mean by torque to 40 lbs?
Old 03-25-11, 09:15 PM
nine3es
nine3es's Avatar
set your torque wrench to 40 lbs and tighten until it clicks, then stop.
Old 08-19-13, 08:55 PM
usman2338
usman2338's Avatar
Default Oxygen sensors
Please make sure that if your car has AFR sensor (air fuel ratio) then you replace it with an AFR and if you have oxygen sensor then r,eplace it with oxygen sensor since signal detection circuitry inside the ECM looks for a specific voltage range for feedback signal. If the feedback signals are different then ECM will throw cel light and could also lead to damaging the ECM. Thanks
techiedude
05-02-12 06:57 PM
dcapo
08-02-11 03:30 PM
mburnickas
05-01-03 11:49 AM
Quick Reply: bad oxygen sensor, can i ignore it?
