Windom Headlight Issue
Old 11-29-10, 06:16 PM
zppeacock
zppeacock's Avatar
Default Windom Headlight Issue
I have windom headlights in my 1994 es300. The marker lights and blinkers are reversed then the normal es300 lights. The factory blinker bulbs are much bigger then the windom 194 blinkers. Which is causing a fast blink from the blinkers and there hard to see. Has anyone rewired and switched the marker lights and blinkers back to the orginal configuration? I have tried a led flasher to try to slow them down but it didnt help.
Old 11-29-10, 09:27 PM
QuachmanES
QuachmanES's Avatar
A LED resistor should do the trick and stop the fast blinking.
Old 11-30-10, 07:29 PM
Megafast13
Megafast13's Avatar
You might as well buy some LED Turn Signals or Switchbacks from V-Led's and also some load resistors, which will take care of the hyperflash and will give a better look.
Old 12-01-10, 09:06 PM
zppeacock
zppeacock's Avatar
Thats what I was thinking also, I ordered 2 resistors from superbrightled.com and will install them friday and report back.
Thanks Guys.
Kenny88880
06-19-16 08:59 AM
westopill
Lighting
12-16-14 06:29 AM
scdroptop
04-23-13 08:28 PM
marcoes300
12-06-10 05:05 PM
Quick Reply: Windom Headlight Issue
