Timing Belt /Water Pump Average Service Cost
Old 10-05-12, 08:40 AM
jcooler
jcooler's Avatar
I just got quoted from Wilkie Lexus $1800 for wpump, tbelt, drive belt and cam seals, anyone know a more reasonable place in the Philadelphia area to get this service
Old 10-05-12, 04:38 PM
cvES300
cvES300's Avatar
wow all of those prices are insane! timing belts and water pumps on our cars r so easy. I don't mind doing them at all especially if u get all the parts from the dealer mainly the t-belt. if I'm not mistaken its every 10 yrs or 100k miles for the belts
Posted from ClubLexus.com App for Android
Old 12-27-13, 07:23 AM
KathyC
KathyC's Avatar
I got a quote for $1760.00 to change leaking water pump, timing belt(my car only has 66700 miles) and valve casket at Lexus of Palm Beach. Does anyone know another place for cheaper?
Old 12-27-13, 07:25 AM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
Ask your toyota dealer they can do it, and save you money. Or find a good independent shop in the area.
Old 12-27-13, 09:47 AM
mitmaks
mitmaks's Avatar
Find a trustworthy mechanic who does side jobs and have it done for $200-$300
Old 12-27-13, 11:42 AM
rlx101
rlx101's Avatar
here is a web site that gives good estimates for the repairs in your particular area: http://repairpal.com
i get $720-980 average quote for t-belt service (+pump etc) in my area from independent shop.
Use yelp.com to find a repair facility in your area with excellent reviews, then give them a call and schedule an appointment.
It is money down the drain to repair almost 12-16 year old car at the dealer!! This pretty typical repair may exceed 50% of the market value of your car if done through the dealer. Think about it.
Old 12-27-13, 06:22 PM
kakarot
kakarot's Avatar
$300 for OEM parts and 1hr for research on this forum and a couple hr for DIY.
Just got done with my 98 ES300 this summer at 176k.
Old 12-27-13, 07:38 PM
PFB
PFB's Avatar
Occasionally Lexus/Toyota has specials on timing belt jobs, ask around. Also, have them break down the timing belt portion from the quote of the Valve cover gasket portion. Otherwise you don't know if it's a good price or not.
Lastly is it the rear valve cover That they are changing, the front valve cover, or both?. It's usually the rear one that leaks, and it's the most labor intensive to replace. The front one is a very quick job
Overall, assuming even that they replace both valve cover gaskets, the price quoted to you is on the high side.
Phil
Old 12-29-13, 08:41 AM
OceanView
OceanView's Avatar
I just had an indy do this for me for $400 including parts.
He replaced Timing belt, water pump, Tensioner.
Old 12-30-13, 06:51 PM
Power6
Power6's Avatar
I had mine done a few months ago, at Toyota dealer, was surprised the job was $680 that was just strictly the timing belt/water pump job I asked them to do the cam/crank seals and some other stuff as well, was outta there for a about a grand, and they gave me a loaner too, was a Yaris but hey saved a bundle over the Lexus dealer.
I tried some local Toyota craigslist guys but they were hard to pin down, I just wanted it done right and guaranteed to use OEM parts the Toyota dealer was very reasonable.
Old 12-31-13, 07:00 AM
Mythotical
Mythotical's Avatar
I do 1mz timing belts all the time on the side for $400 + parts. but I also do the cam seals, valve cover gasket and oil pump seal and sometimes include the tune up all in the same job.
Old 01-04-14, 03:49 AM
tkbalt
tkbalt's Avatar
Just had 90K service done on an 01 - 90K service with belts, water pump, throttle body clean - $1300
Old 01-04-14, 09:58 AM
cougrdad
cougrdad's Avatar
as a retired Lexus service consultant; I learned first hand about timing belts installed ONE TOOTH OFF. Vehicle not passing smog, multiple trips back to the side mechanic before coming to Lexus dealer to repair problem.Word to the wise you get what you pay for.
Old 01-05-14, 09:39 PM
yeskay
yeskay's Avatar
do it with toyota certified mechanic. purchase oem parts directly and supply it to mechanic. it was $100 labor few years ago when i did mine.
Old 01-14-14, 01:38 PM
Snoope
Snoope's Avatar
I just got a quote from my NH Toyota dealer for $625 out the door BUT that was not before I "Beat'em up" a little with an "Indies" qoute of $450-500...
They both are using Toyota OEM parts but the dealer's work will carry over to any Toyota shop nationwide; good for me because the Lexus will be "living' in Florida by March..
Now they may be the exception to the rule BUT they have always tried to "price match" and have taken care of all of our vehicles....
Hopefully I can find one similar in FT.Myers area....
Quick Reply: Timing Belt /Water Pump Average Service Cost
