Replace Outside B Pillar?
Old 10-16-10, 06:28 AM
RXGS
RXGS's Avatar
^ I jsut do it every other time i wash the car, i know its temporary, but the replacement you would buy will most likely fail as well
Old 10-16-10, 07:55 AM
Coulter
Coulter's Avatar
Originally Posted by Lexus2000
That's exactly what happens. My left hand side one is starting to do this, I thought about putting chrome covers on them, but I don't really like the look. Problem is, the replacement will just fail eventually as well.
That was my problem with buying new ones (along with the cost) but I can see them lasting 3-5 years before any issues re-develop.
It's unlikely I'll still have the car then, but even if I do, buying new ones in 2015 is not the end of the world. At that point though, this car will probably have so many miles and wear and tear, I won't care anymore.
Right now though, the car really is in mint condition, and it was the one thing that made it look old and dated.
Old 10-31-14, 06:52 PM
Jumpingpc
Jumpingpc's Avatar
Originally Posted by Coulter
On my 99 Es300, the black plastic piece that lays in between the two windows looks awful. I know this is a common problem, has anyone replaced this piece with a new one?
Is this an easy DIY project? Does it just pop off?
Any advice would be appreciated, it really makes my car look like crap.
Thanks
Yes!! I replace mines they pop right off. You can use a tool called panel popper or a flat head screw driver just pry it away from the cars body and you will be fine...
Old 11-03-14, 04:36 PM
drkandre
drkandre's Avatar
Thanks
So the b pillar pieces are easy to remove if you know what you're doing. I found two in good condition at my local pick and pull yards. I've replaced both of mine without breaking the clips or the clip retainers. Patience is key! I can take pictures and provide a write up if still necessary.
Old 11-03-14, 05:43 PM
drkandre
drkandre's Avatar
Here's my write up, if anyone is interested
https://www.clublexus.com/forums/es3...m-removal.html
Getlowe415 (01-11-22)
Old 09-08-16, 03:09 PM
AlanLS430
AlanLS430's Avatar
My pillars are cracking and breaking from hot sun damage, so bought a whole kit online for about $35. The one challenge I have is that one of the pillars has lost 80% of the plastic, but the 20% that remains is glued tightly to the pillar. I've been attacking it with a putty knife, but it s slow go. I am concerned about adding the cover to an uneven surface, so I want to remove it all, if I can.
rhlitt334
ES - 6th Gen (2013-2018)
11-06-17 05:39 PM
p3style
01-06-13 05:34 PM
LTDTeam
08-04-10 09:13 PM
unreeaal
04-27-10 08:07 AM
Quick Reply: Replace Outside B Pillar?
