92 es overheating question
bought my es300 knowing it was overheating.
Flushed the radiator changed the water pump changed the head gasket and boiled the thermostat and it is opening. When i run it the upper radiator hose is burning hot and the lower is getting no heat the only thing I can think of is the water pump is defective and i need to get another one. is there anything else i should be aware of to check. Thanks for your time
Minimum pressure: 145 PSI (10.2 kgf/cm2)
Difference between each cylinder: 15 PSI (1kgf/cm2)
99LSprobs
06-12-18 02:31 AM
MyEs300Yea
07-21-11 11:20 AM
