Passenger rear door won't open from inside
Old 09-18-10, 03:17 PM
rossirjr
rossirjr's Avatar
Default Passenger rear door won't open from inside
I'm hoping someone can shed some light on a problem with my 2004 es330.
The rear passenger side door will not open from the inside handle.
I checked the child lock setting and it was off, turned it on, made no difference, turned it back off.
The power locks work fine, just can't open the door from the inside.
Can the child lock get stuck or something?
Thanks
Russ
Old 09-18-10, 08:11 PM
GEORGE_JET
GEORGE_JET's Avatar
One of the plastic clips that hold the rods in place is probably broken or loose, but that is not the only thing it could be. You will have to remove the panel and see exactly what is wrong.
If it is a clip, most auto part stores carry a selection, and would possibly have what you need.
masterff
08-03-15 07:16 PM
Handsome
SC- 1st Gen (1992-2000)
07-08-13 09:54 AM
TNH
09-18-12 08:33 PM
bezee
04-07-09 09:07 AM
93sc3005sp
13
05-11-08 03:45 PM
Quick Reply: Passenger rear door won't open from inside
