Plenum Gasket
Plenum Gasket
95' ES 300
Im needing to replace the rear valve cover gasket as it is leaking. I know i have to remove the intake plenum. My question is can i reuse that gasket? or is it a one time use type gasket?
You can re-use any gasket if you want to. But should you? No. There are a few exceptions, drain plug gaskets, thermostat, a few others.
But in this case, use a new gasket.
BlackIRON
Performance & Maintenance
06-01-18 01:31 PM
TriniLex
02-25-18 10:47 PM
maniax
22
07-04-15 06:26 PM
