KYB GR2 struts on 1999 ES300 121k
Old 09-04-10, 06:05 PM
Mylexus1
Mylexus1's Avatar
Default KYB GR2 struts on 1999 ES300 121k
I don't get everyone on this forum saying these are close to the original ride and I replaced all four in June 2009 with KYB's and they ride horrible.
Very stiff and feel every bump in the road now I hit a pot hole and sounds like they bottom out...... nearly knock the fillings out of your teeth.
Wish I had my old ones back on.
Anyone else experenced this? I am considering Monroe Synsa-Trac any feedback on either. ( I have no squeaks and no I did not replace the top mounts)
Old 09-05-10, 08:42 AM
MikeLex
MikeLex's Avatar
I put KYB's on my 94 Camry and, yes, the ride is horrible. Never again. On my 98 ES I decided to go original: 135 each front, 170 each rear, but the ride is perfect...
Old 09-05-10, 09:45 AM
GSteg
GSteg's Avatar
Those KYBs are valved for stiffer springs than what comes with the ES. Mind you many people who have swapped out to KYBs may have higher tolerance for harshness and/or do not know what the original suspension is suppose to feel like.
A lot of cars I ride in with KYB GR-2 do NOT come close to the cushy ride of OEM shocks. If anyone ever wants that soft ride, just get OEM and don't look back.
Old 09-05-10, 03:54 PM
Mylexus1
Mylexus1's Avatar
Thanks for the reply guys.
Glad to hear I am not imagining this. Yes these are coming off.
Where did you get the parts from and did you replace the top mounts?
Old 09-05-10, 04:50 PM
Maxx941
Maxx941's Avatar
Most here probably use KYB-GR2 matched with some lowering springs, only other suitable strut for lowering is the Tokico struts which are even stiffer. OEM struts should not be used with lowering springs, so for OEM ride yes OEM struts are best.
Old 09-05-10, 05:32 PM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Cool
Granted it's their own site and language, but "The best choice to restore OE performance and normal driving conditions": http://www.kyb.com/products/shocks/gr2.php
There are SO many other factors and components that can figured into the equation of the softness or firmness of your ride, especially on an 11 year old car. I'll edit the post with the other manufacturer when I can recall it but Gabriel, KYB and _______ were the sources of the original equipment dampers for our cars.
I've tried a few different suspension setups on my car. I now have the GR-2s plus the OEM Lexus springs and new bushings on my ES and the ride is
plush, sharpened only with the Whiteline rear sway bar and Whiteline strut tower brace. It's interesting to think that mere damper replacement might affect the ride that differently (all other things being equal) between the Gen 2 and Gen 3 ES.
Old 09-05-10, 05:34 PM
Mylexus1
Mylexus1's Avatar
Mike,
Where did you order these from?
Old 09-05-10, 06:05 PM
D-Boi
D-Boi's Avatar
thats good to know, i was contemplating on getting the kyb's for the ES because they are alot cheaper than oem but this car is all about comfort for me im not lowering it or anything so thanks for the heads up guys
Old 09-05-10, 06:19 PM
PlatES300
PlatES300's Avatar
In all honesty, I've replaced my OEM with the gr2 and stock springs and they ride fine. A tad bit more firm than stock, but nothing that should jar or rattle you out of your seat. To me, it rides more firm than stock - you don't get that boat feeling as much when you hit dips and bumps.
Old 09-05-10, 08:51 PM
Mylexus1
Mylexus1's Avatar
I think they would be more suited for my 4-runner than a Lexus. I had no idea that they would be this stiff, but I would think most people bought this car for it's smooth ride like I did. They do defiantly hold the road better on curves at high speeds I have noticed, but most driving is around town. I think the original fronts were fine it was the back one's that would bottom out when I had two adults in there and went over a bump, it was actually embarrassing to be driving a Lexus and have this happen.
Old 09-05-10, 09:00 PM
Mylexus1
Mylexus1's Avatar
Was Tokico the other one?
Old 09-05-10, 09:13 PM
GSteg
GSteg's Avatar
Toyota uses many aftermarket companies. Tokico is on the list and so is Bilstein.
But like any engineering, Toyota specifies what they need and the suppliers build their shocks to satisfy Toyota. Of course the shocks they sell to the general public are usually valved differently.
Old 09-05-10, 09:22 PM
MikeLex
MikeLex's Avatar
Originally Posted by Mylexus1
Mike,
I bought them in person from Burdick Toyota-Scion, a dealership located in upstate New York.
Old 09-05-10, 10:44 PM
Received 2,708 Likes on 2,293 Posts
I can relate, I put some KYB's on my Camry (car has since been sold) a while back. I was surprised how harsh and stiff they were, and they didn't seem to mellow after a few thousand miles either. The biggest complaint I had about them was they were harsh over small bumps and ripples. They handled big dips and bumps really well, and the car handled very nicely.
But overall I was not that impressed with them, not horrible not as good as the Toyota struts. Next time I'll either get Toyota originals or maybe try out the Bilstein touring units. (they are not available for all Toyota's or Lexus vehicles).
GreatRX300
RX - 1st Gen (1999-2003)
01-21-18 12:27 PM
User3838
07-17-09 09:00 PM
Brandon@TR
Wheels, Tires & Brakes Forum
11-11-06 08:11 PM
bouellet
11-10-03 01:04 AM
sk8er251cc
11-08-03 04:52 PM
Quick Reply: KYB GR2 struts on 1999 ES300 121k
