where is the cabin air filter loaction on 1997 es300
Old 08-26-10, 10:25 AM
es3000714
es3000714's Avatar
Default where is the cabin air filter loaction on 1997 es300
so I can change the cabin air filter where is the location? anyone here?
Old 08-26-10, 11:13 AM
JTS06Z06
JTS06Z06's Avatar
No idea on the older ones but the cabin filter on my 00 ES300 is located to the right of the gas pedal in a white compartment. To get easier access you will have to pull some of the carpet down out of the way and undo one wire harness. Unlatch the door and pull out the first filter. Then you will see an additional tab. This one pull it down then out. Again, this is for my 00 ES300 so it may be different on the older ones.
Hope this helps,
James
Old 08-26-10, 11:15 AM
BDSL
BDSL's Avatar
Right beside the gas pedal....peel back the carpet.
Old 08-26-10, 11:16 AM
PFB
PFB's Avatar
I have a 2001, so mine may be in a different place than yours, but if you look at your owner's manual (if you have one) then it shows you the location, and also how to change them.
If you don't have an owner's manual, than a search here on cabin air filters will do it.
Phil
mitmaks
16
09-20-19 08:19 AM
440guy
04-29-13 08:50 AM
imrat
12-18-09 09:08 PM
Covina
04-26-08 09:21 PM
bfx2460
02-17-05 02:30 PM
Quick Reply: where is the cabin air filter loaction on 1997 es300
