95 Transmission Issues. Check Engine, Idles High
All right been having some issues with my tranny on my 95 ES300. Last November I had to replace the tranny because it was having shifting issues took it to a tranny specialist and they told me my 4th gear was about done. and I noticed that like O/D wouldn't work and what not. Well With this newer tranny I've had some shifting issues before but that was due to the motor mount breaking or coming loose. And in July two seals broke in the tranny and it wouldn't stop leaking fluid but that was about 2 weeks or so ago, I've checked every day and no more leaks it seems. But I am getting some slight shifting issues around 1st gear i believe or right about when i'm going to get into first gear. I don't know if it could be a loose mount i don't think so I had the mechanic take a look he said it looked fine. Also when i'm driving I would say about 5 or so mins later doesn't always happen but happens frequently. I'll hear a whining noise. kind of like the engine is revving but more faint and higher pitched even when the car is on and parked or idling. Also when i change gears, from park to d or reverse and such i can hear it from underneath the car. just sounds loud when it's changing the gear and locking in. I doubt it's supposed to be that loud. Any help would be appreciated. Thanks. Just trying to make this car last, put in so much time money and effort. bleh.
driving today car was being a bit unresponsive rpms would jump but the speed wouldn't increase kept happening. I tried manually shifting gears from L, 2, D then it was working properly again. I'll take it to a shop tonight to have them look at it and the check engine light. can't take much more of this, Anything else you guys can recommend? what other things can i look into to make sure it idles lower when i first start the car. i've already cleaned the iacv sensor but that was 2 or so months back but yea. The car idles high when i first turn it on between 1 and 2 but closer to 2.
I also have a check engine light error codes for the O2 and knock sensor in bank 1 i've replaced both of them and reset the codes but they still came on.
But yea any help would be appreciated thank you for your time.
jlaplante
03-25-09 04:43 AM
