94 ES300 won't start on Incline/Angle ?
Old 06-05-10, 07:39 AM
Spimley
Spimley's Avatar
Default 94 ES300 won't start on Incline/Angle ?
ok this morning
i pulled my ES over to the side of the house to use the ciggy lighter to fill up the well pressure tank, started and ran fine,
but I turned it off, parked at an angle, probably 20degrees at the most, and now the car won't start, it cranks but won't turn over.
I can't move it because it won't start and its stuck in park, so two part question...
1) Does the incline/angle have anything to do with it ?
2) To eliminate that possibility, how the fk do I get the car out of park if its not running, so I can move it to flat surface.
Old 06-05-10, 08:35 AM
Spimley
Spimley's Avatar
well, i figured out the "park" situation, found the button, i've moved it to a flat surface, still won't turn over and a jump was unsuccessful, is it Possible that parking it on an incline/angle would affect the fuel system somehow ?
if not i guess this is going to have to wait for a tow to the mechanic monday.
Old 06-08-10, 10:59 AM
Spimley
Spimley's Avatar
the culprit is found ! Ignition Fuse...
Old 06-08-10, 11:43 AM
frohboy33
frohboy33's Avatar
Glad I could help! J/K glad you found the problem, beats having to pay for a tow.
Camsdad68
03-08-14 09:00 PM
duytb
01-07-14 06:33 PM
apoxc69
12-13-11 05:46 PM
ourmethod
28
12-19-09 06:16 AM
heyboy
05-22-05 08:48 PM
Quick Reply: 94 ES300 won't start on Incline/Angle ?
