Please Help/Advice I need to replace my Cup holder
Old 06-04-10, 01:08 PM
TomsES330
TomsES330's Avatar
Default Please Help/Advice I need to replace my Cup holder
I have a 2004 ES330 I broke the front cup holder in the Console )-:
I need to know how to take apart the console
Old 06-04-10, 02:53 PM
JSM1284
JSM1284's Avatar
Alright, Im not good with writing up these DIY things, But here goes nothing.
First, Start by setting the parking brake, Turn the key to the "on" position and move the gear selector into "N". Pull up on the shifter trim bezzel to remove. Once removed, unplug the electrical connections for the cig lighter, and Rear power sunshade if equipped.
Once removed, Remove the two small Phillips screws as shown below:
Next remove the small pieces of felt/carpet at the bottom of the center console, and up on top to reveal the two 10mm bolts in the bottom, and the two phillips screws up top. Remove the screws and bolts:
Once all bolts and screws are removed, You should be able to pull the entire console up and back to gain access under the cupholder:
To reinstall, just move in reverse order. Let me know if you have any questions.
Total job only takes about 15-25 minutes, depending on your skill level.
Josh
Old 06-05-10, 06:39 AM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Thumbs up
Wrong!
Your helpful posts and DIYs like this rock!
Old 06-05-10, 01:59 PM
JSM1284
JSM1284's Avatar
No, No Scott. You are the helpful one!!! You are the reason I still have my baby!
Blueshark
ES - 5th Gen (2007-2012)
08-09-14 03:46 PM
tsxnbp
06-16-14 08:30 PM
Nexevious
SC- 1st Gen (1992-2000)
12
06-06-14 07:32 PM
t70 supra
10-30-08 08:32 PM
Quick Reply: Please Help/Advice I need to replace my Cup holder
