94 ES300 Coolant Leak
A couple of days ago I noticed that my 94 Lexus ES300 temperature gauge was showing the car running hot. I pulled into a shopping center parking lot and checked the coolant level. I found coolant still in the overflow tank, but little or none in the radiator.
After purchasing a couple of gallons of coolant and pouring it directly into the radiator with the engine running I began to see some leakage under the car. When I turned the car off the coolant leaked out quickly.
It seems to be leaking under the pulleys and belts. After seeing this I assume that the likely problem is that the water pump has worn out. I am planning to take it to a garage tomorrow, but I was wondering if anyone could think of any thing other than the water pump that might cause coolant to leak out below the pulleys and belts.
fade41
14
04-20-16 09:13 AM
squ
13
01-13-06 09:35 PM
