My ES launches slow compared to Camry
Here's the scoop, 2 cars:
My '93 ES300, 100k miles and just had to replace the transmission. New Lex plugs at 80k, Yokahama Decibels, anything else I should note?
vs my mother's '98 Camry V6.
I would say that acceleration above 50mph is similar, but the Camry launches much quicker and pulls quite a bit harder. Haven't timed them with a stopwatch or anything, but I know I'm not imagining the difference in acceleration.
Anyone else driven both cars in the same generation? Or if not, how hard does your ES launch? Although my tires have better traction than stock, I'm unable to break the tires loose on dry pavement from a dead stop. In the Camry, although it has some cheaper Yokahamas, I can punch it at 15 mph and break the tires loose. Does this seem off?
Guest
Posts: n/a
So your mother anticipated the launch? One of the factors you have to consider is that your ES is a lot older than the Camry. I once raced my 97 M3 with my friend's 97 M3 (both had no engine mod at all). Same generation but his car has 20k more mileages and you can really see the difference.
Super Moderator
maybe you have a *doomed* ES. j/k. check those air hoses people! and your motor mounts. the tires you got on shouldn't really be a problem unless you got the new tires because you got really heavy aftermarket wheels or something. plus, yokohamas are generally soft rubbers. maybe your mom's camry doesn't have that spare tire in the trunk or something. i dont know. what happened to your transmission anyway?
and i used to be able to burn my tires but they were really bald. i got new tires and i cant do it anymore.
Breakin' Loose
w0rd, I wish I could break the tires loose in my 96 ES....I've only been able to do it on wet pavement. Just got brand new Continential (sp) tires though, dont want to wear em' too fast.....
i got new tires too, i used to neutral drop all the time. left lots of smoke. now i have my new tires, and its harder to break loose. but i still can, and if you are having trouble spinning from a stand still, try turning the wheel left or right when accelerating, the wheels break loose easy. i can burn with the e-brake on
The reason I mentioned the tires is because I think that my tires, on the ES, make better traction and would be a bit harder to break loose. However, I know there is still quite a difference in acceleration. I know the '93-'94ES has a different engine than a '98 Camry so this is part of the reason, just wondering if I should have similar acceleration or if my car is a slow ES.
I'd take it down to the drag strip to test, but I don't feel like spending $20 to get beat by barely-modded civics and pickup trucks.
I purchased my ES a little over a month ago, and it had some transmission problems. The clutch packs were worn, not sure for what reason. After a rather large chunk of change the rebuilt I had the transmission replaced with seems to work well. Wish I would have posted earlier in the "maintenence" section though, as I'm told I could have requested a rebuilt with a better torque converter, which would help it off the line - and this wouldn't have cost any more money. Too late now.
On the plus side, I refinished my car today and it turned out quite well. Wet sanded out the scratches, used 3M rubbing compounds, and Wizards Sealant and Polish. Shines like new.
No neutral drops please! Automatics aren’t made for that! Maybe step on the brake then the gas and then once your revved let the brake go, that’s much easier on your tranny then revving in neutral and then dropping it into gear. Ouch!
Camry
A little late reply..
When I blew my motor, I replaced it with a Camry 3l. I had to change a number of censors etc as well, but the engines a re virtually identical. I have now tried to take on a 3l Camry and it does take me on the pull off. It felt to me as if my Lexus was heavier and as if the transmission changed at the wrong shift points.
Regards
Ferdi Kruger
South Africa
Regards
Ferdi Kruger
South Africa
Overdrive allows the transmission to select fourth gear sooner and more often, for better fuel economy. ECT button raises the shift points a bit, to get the most out of each gear and to keep teh engine in the optimum part of the power band when shifting to the next gear.
