Performance Mods
i have a problem. i can't change my filter. how do i take off the airbox, and replace it with a K & N cone filter. WHere do i remove the airbox at. What about the altitude sensor?
you have to remove your stock airbox then connect the MAF adapter to the maf then use the clamp to connect the KN filter to the adapter. Hopefully you did not buy the adapter the other guy was trying to sell because that thing will not fit your car.
SUGI
SUGI
Chicago Lexus Club Moderator
It should fit on the 92-95 es. It is fairly easy to install. You will get intructions with it so it won't be to hard. I think that who ever found this did a good job, and by the way to get an exhaust, you have to have acatback built for our car and it will cost around $ 400 for that and the muffler installed.
Adam " Lexist "
Adam " Lexist "
kaytoven
ES - 7th Gen (2019-present)
33
01-21-19 03:52 PM
