need help with es 300 air bags 1997
Old 11-23-09, 05:55 PM
rexdeans
rexdeans's Avatar
Default need help with es 300 air bags 1997
I am changing air bags and need some additional help
Old 11-23-09, 06:19 PM
Sammm
Sammm's Avatar
There are two t screws on each side of the steering wheel under a plastic cover that you must pop out. Remove these screws - airbag comes off and then unhook connector. This has been covered before. Do a search.
Old 11-23-09, 07:30 PM
GEORGE_JET
GEORGE_JET's Avatar
Make sure that you disconnect the battery and give it a few mins to discharge before proceding. One other point, place the airbag FACE UP whenever you put it on any surface. IE table, benchtop, etc. If the bag deploys you want the bag to coming at you, as opposed to having the metal mounting plate on the back of the unit coming at you.
A subtle point, but very important. This was much more important on the first generation bags, but still holds true today.
Old 11-24-09, 12:53 PM
angmedic91
angmedic91's Avatar
May I ask why your changing air bags?
Moohamp
04-18-20 03:50 PM
hsmac
RX - 1st Gen (1999-2003)
05-23-16 08:50 PM
tbilisi79
06-23-15 04:53 PM
shabbyblue
03-15-12 09:06 PM
Quick Reply: need help with es 300 air bags 1997
