11-04-09, 06:59 PM
Headlight aiming problem
hi i ordered some HID's that came into and i installed. my headlights are off alignment. the drivers side is low and passenger side is high. i tried to align the passenger side with an 8mm socket. i kept screwing it in and out would not adjust at all. am i doing it wrong? please someone help me. thanks!
__________________
00-01 tail lights|toyota oem lip|Work Euroline DH rims|20% tint|intrax Springs|KYB & TRD struts|TRD rsb|solara stb|RRM intake w/ custom cai|00-01 wood steering wheel|eclipse avn5435|alpine type R|infinity & JL components|rockford 1000.1|orion 225 hcca|more to come...
11-04-09, 07:48 PM
anybody? i searched it but nothing really useful came up. please somebody help asap i cannot see while driving.
__________________
11-04-09, 10:59 PM
Make sure you are turning the right one?
The manual states as to which one to adjust/where & how...
I did mine in a whole 3 mins, and they were good to go.
11-05-09, 01:03 AM
okay well i figured out the driver side.. its the screw right next to the high beam. but when i tried to do the same on the passenger side it would not work. any ideas?
__________________
11-05-09, 08:03 AM
Quote:
No clue. And i would take a look but knowing my 2001 it is bound to be in a different spot...
Ie. Fog lights in the 00-01, mounting points are different than the earlier years, i thought i was removing it, but i ended up screwing up the adjustment simply by turning what i thought was holding it in place...
11-05-09, 01:48 PM
1998 Lexus ES
I have a 98 ES300 and my adjustment bolt is 8mm and is near the top, between the lowbeam and hi beam light. you also should have bubble levelers on the top to let you know when your headlights are level. First park your car on a level surface, then to adjust up, facing the the headlight, turn bolt to the left with a 8mm wrench or socket, its the same for both lights and to lower the light, you turn the bolt to the right. BTW BL155, where did you get your Toyota front lip from? If I was to order it, what make and model car? Thanks.
__________________
Robert
http://www.clublexus.com/forums/es30...-es-300-a.html
HID 8k LB & 6k DL/18 x 8.5 Boze iForged/Drilled & Slotted Rotors w/Ceramic pads/Clear Corners/K&N Intake/NST Underpulley/NGK Laser Platinum Plugs/Optima Red Battery/Solara Strut Bar/Chrome Fender Trim/Window Tint/Pedal Covers/00-01 Wood Grain Steering Wheel/Wood Dash Kit/OBX-R Shift Knob/LED Interior & License Plate Lights/Chrome Pillar Posts/Chrome Magna Flow Exhaust/LED Rear Spoiler/00-01 Taillights
11-08-09, 06:01 PM
Quote:
It was bought somewhere in hong kong, but i dont know the place because I got it as a gift. It would be for the toyota windom but its not an easy find.
__________________
Tags
300, 350, adjust, aim, aiming, es300, gs, gs300, headlight, headlights, lexus  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
