10-18-09, 10:20 PM
timing belt (2004 es 330)
I was wondering if anyone had changed their timing belt to see how difficult it would be to do a diy. If you think it's better to have a shop do it, would it be very pricey to have it done on these cars? Thanks in advance.
10-18-09, 10:24 PM
1992 Lexus ES My Garage
If you have ever done a timing belt change, you would know what you are doing. If not, then leave it to the pros. It's not simple as an accessory drive belt change.
10-19-09, 09:42 PM
Quote:
O.k. So I guess I'll call around some shops to see what labor would be on these cars. So probably every 60k would be a good idea right? When that time comes, would you recommend changing the water pump and thermostat too, or do those last a while?
10-20-09, 04:44 PM
I spent about $750-ish on water pump and all those stuff. i did mine when my 03 ES was 87K. and yes, let the pros handle it, it's not an easy job, at least from what I see.
10-20-09, 11:28 PM
2003 Lexus ES
as a technician i can say leave it to the pros...it is not a DIY job unless you have some more serious mechanical experience beyond changing oil and brake pads.
__________________
"The Starship"
2003 CWP Lexus ES300 - MCV30 - 1MZ-FE
NELOC GO RAVENS!
10-23-09, 08:43 PM
I had mine done at the Toyota dealer last year. $800.00 for the timing belt, accessory drive belts, water pump, main oil seal, cam seal, and thermostat. I was going to change the belt tensioner too, but the dealer said it was still good. It's cheaper to bundle as many preventive maintenance services as you can at once.
__________________
2003 ES300
2007 Camry LE
1993 Toyota 4x4 Xtra Cab
1964 C10 Custom Cab
10-23-09, 11:49 PM
Did it on my 01 ES last week. $750 for a completed package:
- Timing belt.
- All accessory belts.
- 2x timing belt idler.
- Belt tensioner.
- Water pump.
- 3 seals (forgot what the name?).
All OEM, not aftermarket. As gulffishin said, change as many items out as possible. It is the labor cost that will hurt you later if 1 item fail.
Good for another 90k mi. Hopefully by that time, I will be able to get a "new to me" ES350.
10-25-09, 04:07 PM
2003 Lexus ES
its true...bundling services together saves money.
750-800 is a great price for getting all the major service work done.
__________________
"The Starship"
NELOC GO RAVENS!
10-25-09, 11:45 PM
have a shop do it and do all the maint that is needed around the same area. timing belt, water pump etc
__________________
2005 Classic Silver Metallic ES330, 19" Axis Mod w/ Maxis Lip>RIP 20x8.5 Axis Orden>RIP,20x10 Axis Groove, Tanabe NF210s, 3000k Fog HIDs
2002 Noble Green Pearl Accord V6 EX Tein S-Tec, AEM CAI> RIP
1990 Pearl White CRX B20/VTEC, Wings West Kit, Si Wheels, Integra Leather Seats, TEIN SS
2008 Galaxy Gray Civic Si Sedan 8000k HIDs
Tags
04, 2004, 330, belt, chain, changed, es, es330, gs300, gx470, is300, labor, lexus, replacement, timing  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
