my 95 es 300 having problem
i took the car to my lexus dealer they could not find the solution
then i press brake pedal my headlights and deshboard lights
dime down some times my radio goes off and then comes on
if anybody can help me
Thank you
Thank you
hook up a volt meter to your car, see how much voltage is droped
when you press the brakes. If there is more then 2 volts there may be a problem with your batt. holding a charge. abd or the
atl. is not charging the batt. Do this press the gas ( be in park)
and press the brakes, see if it happens. While pressing the gas, your increassing the RPM and should be charging the batt. If the lights don't dim, you may need a battery, see the battery may not be holding a charge. Where do you live?? is it cold there??
nicks88
26
02-07-11 10:09 PM
