ES 300 loosing Power...
Old 05-21-09, 11:47 AM
karhey
karhey's Avatar
Question ES 300 loosing Power...
Hello all,
I am new to this forum and would like to get some hints for my 2000 ES 300 from all you great guys
Recently the car is loosing power (above 2200rpm) and the engine starts to sound "Nosier" when i rev it up to 2200rpm.....
Everything sounds 100% normal (the perfect lexus quiet) when its not being rev-ed up to 2200rpm!
Where should I start looking at? Oil Change? Spark plugs? or Tranny oil ? etc? Any hints/experience/suggestions welcome!
Thank you very very much in advance
Old 05-21-09, 12:04 PM
Maxx941
Maxx941's Avatar
Welcome to CL
Try checking for any loose or leaking vacuum hoses.
Old 05-22-09, 09:41 AM
karhey
karhey's Avatar
Thanks Maxx941,
I will try look into it Thank you very much for the info!
Is there anything more to look at?
Old 05-22-09, 11:43 AM
mmatheny
mmatheny's Avatar
What year - how many miles?
Old 05-22-09, 11:56 AM
GEORGE_JET
GEORGE_JET's Avatar
Hold a rag over the exhaust and have someone give it a little throttle, listen for exhaust leaks.
Old 05-23-09, 10:58 AM
karhey
karhey's Avatar
yr 2000 ES 300, about 50000miles on it only....will a spoiled spark plug cause the problem?
Old 05-23-09, 11:41 AM
GEORGE_JET
GEORGE_JET's Avatar
Fouled spark plug is better a better term to use, sounds better! Yes a fouled plug will cause a miss, normally you would notice it at all speeds. 50 k miles is not that much for a plug, lexus recomends replacement at a much higher mileage than that. I myself prefer to change then at around 50k. It would certainly not hurt to change the plugs, pay close attention to the plugs you pull, and what cylinder. Especially check for oil on the outside of the plug, that would foul a plug.
Old 05-24-09, 09:06 PM
llcoolpass
llcoolpass's Avatar
did you mean to it's noisier when you rev is past 2200 RPM? also, is it making a noise or what? did you check the oil level [properly]? when did this start? have you been following the maintenance schedule? can you post a video clip with good audio demonstrating?
"Recently the car is loosing power (above 2200rpm) and the engine starts to sound "Nosier" when i rev it up to 2200rpm.....
Everything sounds 100% normal (the perfect lexus quiet) when its not being rev-ed up to 2200rpm! "
hawkman2
02-04-19 07:08 AM
Bumbobee
12
08-07-11 01:06 PM
93ES5speed
10-23-10 09:40 PM
nycxqueens
Maintenance
07-17-01 09:39 AM
Quick Reply: ES 300 loosing Power...
