ABS light always stay on 93 ES300
After replacing the front strut myself, the ABS light always stay on when the engine is running. Can anyone give me a few pointer where the problem might be? I can't think that this is an ABS problem since prior to getting the strut replaced, it was just fine.
Thanks in advance for your help
ABS Light
Any problems you have with the gauges or cluster, I recommend to have it looked atprofessionally. ABS is important. You may have not hurt it, but you may have disconnected the signal cable or something similar to that. At least if you have it looked at, then they can let you know the seriousness. You don't want to be driving, and have to use your ABS and then go into a skid because they aren't there. Hope this helps some.
I have the exact same problem with my 93 ES300. Both front axles were removed and the ABS light remains on. The problem is both front wheel speed sensors were damaged as determined when having the car hooked up to a computer. The wire that connects them should be treated with care and weren't. It is called wire stripping and is about a $400 problem. This is a common problem.
I am going to fight to get the garage to pay for it.
You still have regular brakes though.
malten02
11-24-10 05:26 AM
