1998 ES300 intermittently not starting
Old 02-19-09, 12:34 PM
PeterGo
PeterGo's Avatar
Default 1998 ES300 intermittently not starting
100k mileage...w/i the past 3 months, especially when sitting overnight (No.Fla.), the car will not even turnover when starting attempted.There is a single 'click', lights etc go on but no cranking.This repeats for a number of attempts, then starts w/o hesitation, especially if key is 'wiggled' in starter switch. Battery, cables, connections etc checked OK by certified mechanics times 2.All 3 transponder keys elicit this scenario.
I noticed that when using an 'emergency entrance key' w/o a transponder I had made makes the same 'click' & of course no starting.No other problems.
Could this be a problem in the transponder 'system'? I read there is a transponder amplifier but in this car?
Help!
Thanks,
Peter Go
Old 02-19-09, 12:46 PM
BDSL
BDSL's Avatar
Can be faulty starter relay or ignition switch.
Old 02-28-09, 05:58 PM
eslex96
eslex96's Avatar
I had this issue on my 96 es300. I pulled the starter and solenoid. The contacts had wore down and were not making the connection to the starter motor. There was a fiber washer (maybe a buffer washer) that cushioned the contacts. I was able to break it and remove it, this allowed the contacts to make a solid connection, I haven't had a problem with it since. But I only bought myself a little time before the contacts wear down a little more, then I will have to replace the solenoid contacts.
Regards,
Old 03-01-09, 11:40 AM
Lazy
Lazy's Avatar
My guess is your starter or the contact to the starter/ignition switch.
Whitenova
17
06-04-13 06:15 PM
jcastaneda
02-02-11 09:46 AM
meanboy
04-22-08 02:22 PM
ancdmd
04-21-08 05:25 AM
vtrd00d
Maintenance
05-04-05 10:27 AM
Quick Reply: 1998 ES300 intermittently not starting
