I just changed my Transmission Fluid
Old 01-31-09, 02:42 PM
ALarsh
ALarsh's Avatar
Default I just changed my Transmission Fluid
Well first off, after reading a lot of the threads everybody was saying to only use Toyota ATF IV. I went to the toyota dealer and asked them for some and they advised me my car needs Dexron III fluid... not the IV or WS (1997 ES300). Sure enough I went out to my car and checked the dip stick... it said Dexron II/III.
Make sure you guys don't just dump in IV into it cause it says so on the forum. Check your owners manual and dip stick! I almost made that mistake.
So off I went to napa to pick some up, dropped out the old oil, put new in. Now I am trying to figure out how I know if my transmission is up to temp? The oil pan is warm to touch but the fluid is definitely not warm (I drained a little out and cool to touch). I took it for a drive around the block and not much movement in level. Right now it is at the bottom of the hot mark... but I guess I was going to let it sit overnight and then check on the cool side of the stick?
Suggestions?
Old 02-01-09, 07:13 AM
BDSL
BDSL's Avatar
Yes, use Dexron III.
3 quartz is enough.
Old 02-02-09, 11:19 AM
Walnut
Walnut's Avatar
Amsoil Synthetic ATF. Car runs purrrrrrrr-fectly.
Old 02-02-09, 01:29 PM
97'ES
97'ES's Avatar
Drive the car for 10 or 15 minutes and allow the temp. gauge to get to a normal operating level. Then check the fluid with the car running. Shift through the gears manually and recheck a couple times.
Old 02-08-09, 07:59 AM
alaskaty
alaskaty's Avatar
Should I stick with Dexron III or would Dexron VI be superior?
Old 02-08-09, 01:08 PM
ALarsh
ALarsh's Avatar
I stayed with III but i'm pretty sure you could use IV if you want. I think they are interchangeable as each fluid supersedes the next, but wait for other input before using IV.
OceanView
15
07-13-19 04:41 PM
rainmn
GX - 1st Gen (2004-2009)
03-16-11 11:28 AM
brenjmull
08-08-08 07:44 PM
Vitaliy23
05-08-07 07:29 PM
cenwesi
04-13-06 11:26 AM
Quick Reply: I just changed my Transmission Fluid
