'00 es 300 tail lamp problems
Here are my problems. I just noticed all lights connected to truck don't work: reverse light, license plate light, etc. Checked fuse, fuse is ok. Funny thing too now my check engine light is on and TCS off light is on. Also the reverse indicator light is on too. After I start the car several times, the reverse indicator light would turn off, but will turn on later, say again after several starts. Also with the key in on position and trans in reverse the license plate light sometimes turns on, and if I turn on the lights then the license plate light turns off. Battery is good. Oh yeah the button to open the truck does not work too. I hear the relay clicking but the truck doesn't open. I am thinking the wire that runs to the trunk, there must be a loose connection or a short. I am going to have the check engine light checked Monday maybe that will steer me in the right direction, but does anyone have any idea what is causing my problems. I'll take any suggestions, so I can check on it tomorrow. Thank you in advance.
yummytyson
07-23-09 12:07 PM
