AC light Blinking and AC not working..........
Old 04-15-16, 02:59 PM
  #106
geddymd72
geddymd72's Avatar
Default Quick check and easy fix
Blinking AC light? Swap the horn relay with the AC clutch relay to identify the culprit. Then try banging the old relay a few times with a screwdriver head. When you reinstall it, it may start to work again as it did for me.
This video shows what to do:
https://youtu.be/b-oETQXoe0g
Old 06-30-16, 06:20 PM
  #107
redwayhorn
redwayhorn's Avatar
Default June, 2016 Update Blinking A/C Light
The A/C light started blinking on our 2003 Lexus ES300. Car has 75K miles on it. Today (6-30-16) we purchased a Magnetic Clutch Relay replacement part from our local AutoZone. Took the original Toyota/Lexus part with us (as mentioned, it's located in Fuse Box under hood - ours is white). Just wanted to be sure AutoZone sold us right part. The part purchased has a lifetime warranty and the mfg./part # for the relay is Duralast 20382. Cost was $16.99 + $1.40 tax for a total of $18.39. A/C is ice cold, runs perfectly, and no more blinking light! Highly recommend you try this method first before having any expensive A/C repairs. DO NOT buy the part from a dealer - it's way more expensive. Good luck!
Old 06-02-17, 10:24 AM
  #108
Simc
Simc's Avatar
Default $18.31 AC fix!!!
I think you were the first to mention this fix
So I have to give you huge kudos!!!!
$18.31 shipped from amazon
thank you!!!
Originally Posted by kashi125
Check the part number on your Magnetic Clutch Relay in the fuse box under the hood. If it has part number "90987-02022" printed on the side of it, replace it with a new relay part number "90987-02028".
This is a common problem with 02-04 ES300 and a lot of Camry, 4Runners etc and there is a Technical Service Bulletin out for it.
New relay is ~$50 online or $75 from a Toyota dealer.
Old 08-10-19, 04:41 PM
  #109
kensis
kensis's Avatar
Default ac not working
read the threads about relay problems my problem is similar except my compressor runs for 5 seconds then off light starts blinking i changed relay no deference new compressor and Freon levels good took to dealer they said i needed new compressor old one was not pumping replaced it new one is pumping now high side is around 150 low side drops when compressor runs but only about 5 seconds turn it off then back on runs 5 seconds light blinks then off read the codes 21 and 24 but i am inside shop does anyone have an idea thanks need help 2006 is 350
Old 05-26-20, 07:24 PM
  #110
Emmydon
Emmydon's Avatar
Originally Posted by llcoolpass
well duh you have a different problem than this person, so why buy a relay you don't need [thought it wouldn't hurt IF your car was covered on the aforementioned TSB] LOL
I guess the AC system has blockage maybe from valve or discharge hose is bad
Old 06-28-21, 10:39 AM
  #111
volvodude
volvodude's Avatar
Default AC Light NOT Blinking - relay?
Hi,
I press the AC button and nothing happens, I don't hear the clutch engage. But the AC Light doesn't blink. It just stays solid green. Can this still be a relay issue? If not what else could this indicate?
I have a 1998 ES300.
Thank you!
Old 06-24-22, 03:01 PM
  #112
arif03es30
1st Gear
arif03es30's Avatar
Red face he light does not blink but it blows hot air :(
Originally Posted by JSM1284
A/C - Inoperative/A/C Light Flashing
ELECTRICAL
EL009-05
June 3, 2005
Title:
A/C LIGHT FLASHING - MAGNETIC CLUTCH RELAY
Models:
'02 - '04 ES 300 & ES 330, '03 - '04 GX 470
Introduction
This bulletin is to provide information regarding countermeasures to the A/C magnetic clutch relay for A/C light flashing (inoperative A/C) issues on some vehicles equipped with a magnetic clutch compressor.
Applicable^ 2002 - 2004 model year ES 300 and ES 330 vehicles.
^ 2003 - 2004 model year GX 470 vehicles.
Parts Information
Inspection procedure
1. Locate the A/C magnetic clutch relay.
2. Verify the part number printed on the side of the relay.
A. If the part number is 90987-02022, please replace the relay with the countermeasured relay P/N 90987-02028.
B. If the part number does not match 90987-02022, then please diagnose problems by referring to the Technical Information System (TIS): applicable model year and vehicle Repair Manual: Air Conditioning: Troubleshooting.
NOTE: Relays other than P/N 90987-02028 should not be used for this application.
Warranty Information
Applicable Warranty:
This repair is covered under the Lexus Comprehensive Warranty. This warranty is in effect for 48 months or 50,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Hi I replaced the relay following everything. Now the light stopped blinking but now it blows hot air all the time. Before it used to blow cold air for a few minutes. Is there any DIY fix or should I take it to professionals? and what could be the possible reason for this? Thank you very much.
Jrocxzs
05-27-20 08:40 PM
niksem
04-07-12 11:29 AM
B4TM4N
04-04-10 08:18 AM
Max Power
10-02-09 07:39 AM
salimshah
RX - 1st Gen (1999-2003)
10-03-08 10:04 AM
Quick Reply: AC light Blinking and AC not working..........
