AC light Blinking and AC not working..........
Old 08-25-14, 09:59 AM
  #91
SmittysGX
SmittysGX's Avatar
Okay I am back on this thread. Does this fix work for the GX470s? I have an 04 GX470 and the AC is now not working at all. I have been able to shut off and or hit the Auto and it would kick back on. It has gotten worse over time and now it wont stay on more than a few seconds. Here is what I got.. What relay am I supposed to replace?
This is my (engine compartment) fuse box.
Not sure if this is the relay to be replaced?
This is what appears on the Nav screen.
Old 08-25-14, 10:19 PM
  #92
repairmatt
repairmatt's Avatar
Yes. https://www.clublexus.com/forums/3572560-post10.html
Old 08-26-14, 07:16 AM
  #93
SmittysGX
SmittysGX's Avatar
Originally Posted by repairmatt
Thank you!
One more question regarding this relay issue. I went to O'Rielly's last night and inquired on the R6034 and they did not have that one. They pulled out 25-0137 and said it was the replacement to 90987-02022. I asked to run a replacement for 90987-02028 and they came up with 25-0279. Has anyone used this 25-0279 relay with any success? I assume as long as it is a cross referenced relay for the 02028 relay it should work. Either way, they didn't have it in stock at the time but will have it by today at noon. I will go pick it up and give it a try this evening unless someone has more information. Thx
This is the relay to be changed....
Here is the one they gave me first, its a tad taller than the 02022 relay.
Old 08-26-14, 02:55 PM
  #94
SmittysGX
SmittysGX's Avatar
Wanted to update all on this.Now this is for a 2004 GX470
I just swapped out the 90987-02022 relay as my AC was not working and showing the "check air conditioner" as shown in my last post. I went to O'Reily's and when giving them the new replacement relay number of 90987-02028, they cross referenced it to this one, 25-0279 (JR66K). I did notice that it shows 90987-02022 right under the 25-0279. I figured I would give it a shot since its $12.99 and see if it works. Lo and Behold, It WORKED!!!! Here is what I got from O'Reily's, Hope this helps....
Old 10-08-14, 12:47 PM
  #95
edd6499
edd6499's Avatar
Default AC will not recharge after compressor install
1998 ls 400. Had the comp. clutch fail, so replaced the compressor with a reman. denso and replaced the dryer. Vacuumed the system down and held a vacuum just fine. Problem is that I can not get the system to take more than about 1/2 a can of 134. Had it vacuumed, released the first can, began to fill, then just stopped filling. Started the engine, turned on AC to see if that would help, but would still not draw it in. compressor engages for about 3-4 seconds, then the light starts flashing and the compressor shuts off. Any suggestions would be appreciated. Thx.
Old 10-13-14, 07:18 AM
  #96
elfy3d
elfy3d's Avatar
I had the same issue a few months back with the blinking AC light. Below is a link how it was fixed
http://my.is/forums/f115/ac-flashing-light-520785/
Old 10-15-14, 02:36 PM
  #97
foxmark
foxmark's Avatar
Default Relay replacement really works.
A/C was blinking and A/C quit off and on. Bought a Toyota 90987-02028 relay on e-Bay for $8 plus shipping. Easy to replace and is working fine so far. Originally bought one at O'Reilly Auto Parts, cross ref. was back to original 90987-02027. Toyota Bulletin referenced in this thread clearly calls for a 90987-02028.
Old 10-17-14, 02:52 PM
  #98
lostape45
lostape45's Avatar
Just curious, what year/model is your car?
Old 10-21-14, 01:07 PM
  #99
albertms3
albertms3's Avatar
Default GX470 2003 - Flashing A/C
So, I switched out the Mag Clt switch to the updated model and the A/C is still flashing. I can turn off and on a few times, then it works for awhile and then it flashes again. I did read in other forums that you are to disconnect the battery before replacing. I missed this step. Thoughts????
Old 02-16-15, 09:42 AM
  #100
krew321
krew321's Avatar
Smile Thanks Old Thread! Saved me Moolah
Thank you everyone who posted here and kept this thread alive. Saved me a nice wad of cash. I went to O'Reilly's and gave them the Toyota part number ending in 90987-02022 and they gave me the replacement part 25-0279 (which as indicated in the thread has the same "generic" number ending in 02022). I plugged it in without difficulty and when the car was started up the AC light had stopped blinking and started cooling. Hopefully there are not any more issues, but my car is already over 10 years old, so here's to another 10!
Old 03-03-15, 02:22 PM
  #101
BillitZky
BillitZky's Avatar
Default ES300 year 2002 blinking AC light
Can somebody please post a picture showing the location of this AC relay in the relay box of an ES300 year 2002. Thank you much
Attached Thumbnails AC light Blinking and AC not working..........-lexus-es300.jpg
Old 03-03-15, 03:34 PM
  #102
BillitZky
BillitZky's Avatar
OK guys found a picture on the threads of postings, this place is cool.
1) Replace the relay
2) If not, charge coolant
3) If not, replace compressor
4) and if problem persist, sell the car!!
Old 03-04-15, 05:39 PM
  #103
BillitZky
BillitZky's Avatar
OK, bought the recommended part at Toyota dealership, $92 and solved the problem, this place is cool, I just cant part ways with my $350 to Lexus..
Old 03-14-15, 05:49 AM
  #104
Claflin
Claflin's Avatar
Hello Everyone
Claflin here. I just joined the forum 2 days ago because I was experiencing problems with my 2003 Lexus ES300
A/C light flashing.
This forum is very helpful and I am very grateful to all of you. As it turned out as several had suggested, the magnetic clutch relay was faulty, and I had the one with P/N 90987-02022 . which is replaced with 90987-02028.
I also found video on you tube where some one had the same problem and all he did was removed the relay from the fuse box , tapped on it and put it right back in and it worked. This is Ideal for any one short on cash as the new part cost about $80 bucks from dealership, but Advanced discount auto has it for $1699+tax.
Old 03-04-16, 12:42 PM
  #105
Jestible
Jestible's Avatar
Originally Posted by Claflin
Hello Everyone
A/C light flashing.
$1,699 is a lot of money for a relay! Wow!
Kidding, alternatively you can order it from Amazon for $25 shipped.
Amazon.com: Genuine Toyota (90987-02028) Relay: Automotive Amazon.com: Genuine Toyota (90987-02028) Relay: Automotive
Quick Reply: AC light Blinking and AC not working..........
