ABS Light On/Trac Off Flashing... NEED HELP!!!
Old 05-16-08, 03:02 PM
shahir18
shahir18's Avatar
Default ABS Light On/Trac Off Flashing... NEED HELP!!!
i just got my suspension changed back to stock, nothing happened to any of the sensors. I even got everything checked with an obdII reader, but no codes came up... any way to get the lights to turn off or reset the light?
Old 05-16-08, 05:11 PM
dallison
dallison's Avatar
probably a wheel sensor. sometimes the strut assembly can drop down on it and damage the sensor or the wiring
Old 05-16-08, 11:10 PM
paintrain
paintrain's Avatar
if u get that obd2 scanner again, u can select clear codes and that should turn off the lights. but im drunk so double chcek er ceck. **** i mean check
Old 05-16-08, 11:30 PM
shahir18
shahir18's Avatar
well nothing came up on the obd2 scanner, so i dunno what to do...
Old 05-16-08, 11:33 PM
paintrain
paintrain's Avatar
u can do what i did with the (E!) brake light. i had the dash apart to put LEDs in for the backlights and since the e brake sensor was messed up i jus pulled out the bulb. no more annoying lights!!!! hindsight being 20/20 it was kinda stupid
Old 04-10-15, 06:34 PM
piseth
piseth's Avatar
I have replace the abs pump, abs ecu, clean the 4 sensor, check the wire. But all everything are ok. At the end it was solved by replace the alternador. It was power supply. All the engineer always focus on the abs system. Seem forget the power supply.
Rishabh1
04-27-23 10:35 AM
Chloelynn
05-14-18 07:24 AM
henry89trd
GS - 1st Gen (1993-1997)
04-22-12 01:45 AM
sik96ls400
12-04-09 03:19 PM
Cannonbear
SC- 1st Gen (1992-2000)
09-26-06 01:06 PM
Quick Reply: ABS Light On/Trac Off Flashing... NEED HELP!!!
